Decryption failed on multiple non-UHD blu-ray discs
Ronny
#1 Post by Ronny » Tue Mar 18, 2025 2:08 pm
It looks like MakeMKV can't do anything with AACS v82
Is there something I should do, or should I just wait?
In addition, my Blu-ray driver supports LibreDrive.
OS device name: F:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.11
Serial number: KLJK4I83733
Firmware date: 2119-02-27 13:19
Bus encryption flags: 1E
Highest AACS version: 82
Firmware version: 3.11
Some dump files are in the attachment.
MKB_v82_UMXK_1124_1262.tgz
(106.74 KiB) Downloaded 432 times
MKB_v82_BD_VIDEO_C672.tgz
(81.44 KiB) Downloaded 424 times
MKB_v82_BD_VIDEO_5BA4.tgz
(142.33 KiB) Downloaded 398 times
Re: Decryption failed on multiple non-UHD blu-ray discs
#2 Post by Woodstock » Tue Mar 18, 2025 2:51 pm
Did you submit the TGZ files to svq@makemkv.com as well? Just posting them here doesn't do that.
Ronny
#3 Post by Ronny » Tue Mar 18, 2025 11:30 pm
Woodstock wrote: Tue Mar 18, 2025 2:51 pm Did you submit the TGZ files to svq@makemkv.com as well? Just posting them here doesn't do that.
I submitted one of them on March 4th, but still can't decrypt.
Ronny
#4 Post by Ronny » Tue Mar 18, 2025 11:55 pm
It looks like someone saw this post and added these three BDs to keydb.cfg, but a generic key for v82 is still needed.
MrPenguin
#5 Post by MrPenguin » Wed Mar 19, 2025 11:00 am
Ronny wrote: Tue Mar 18, 2025 11:30 pm I submitted one of them on March 4th, but still can't decrypt.
Ronny
#6 Post by Ronny » Wed Mar 19, 2025 12:32 pm
MrPenguin wrote: Wed Mar 19, 2025 11:00 am
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMK's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
Thanks for the tutorial.
I know exactly how MakeMKV works with keydb.cfg and I grab the file from http://fvonline-db.bplaced.net/
The 3 dump file I posted here was added into the keydb.cfg by someone today.
I mean a generic key for v82 is needed, otherwise every new BD released will have to wait for someone to update the keydb.
keydb_helper
#7 Post by keydb_helper » Thu Mar 20, 2025 2:31 am
Ronny wrote: Wed Mar 19, 2025 12:32 pm I mean a generic key for v82 is needed, otherwise every new BD released will have to wait for someone to update the keydb.
A device key compatible with MKBv82 was recently posted on the Doom9 forum. Until MakeMKV supports MKBv82, you can generate your own disc keys and submit them to the keydb.
Public KeyDB Disc Submissions
KeyDB Download
MrPenguin
#8 Post by MrPenguin » Thu Mar 20, 2025 11:14 am
OK, sure. But I'm sure your third message wasn't visible when I replied... :?.
bhost
#9 Post by bhost » Thu Mar 20, 2025 2:16 pm
I've been having the same issue..
OS device name: J:
Manufacturer: PIONEER
Product: BD-RW BDR-S13U
Revision: 1.03
Serial number: ...
Firmware date: 2022-07-26
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.03/ID43
I've submitted the tgz to svq@makemkv.com but attached it here as well in case anyone is able to take a look.
bhost
#10 Post by bhost » Fri Mar 21, 2025 3:31 am
Above key has been added to keydb, thanks so much to whoever helped out. If anyone wants to work out on their own how to do it, I was also able to piece together the key using the device key mentioned on the doom9 forum with aacs_info and xreveal's calculate tool. Thanks all!
Ronny
#11 Post by Ronny » Tue Mar 25, 2025 5:15 pm
bhost wrote: Fri Mar 21, 2025 3:31 am Above key has been added to keydb, thanks so much to whoever helped out. If anyone wants to work out on their own how to do it, I was also able to piece together the key using the device key mentioned on the doom9 forum with aacs_info and xreveal's calculate tool. Thanks all!
I tried the method you said, but I can't get the VID. It seems that the HC is not working.
If someone can help me with the attached dumps, I will be very grateful.
MKB_v82_BDROM_E4C8.tgz
(128.36 KiB) Downloaded 418 times
MKB_v82_BDROM_8DB0.tgz
(122.18 KiB) Downloaded 484 times
wyzxvnv
#12 Post by wyzxvnv » Sun Apr 06, 2025 6:02 am
Hello
Please can you tell how or point to some post/article how we can generate own VUK/UK keys (without host certificate but with LibreDrive)?
Thank you so much
keydb_helper wrote: Thu Mar 20, 2025 2:31 am
#13 Post by MartyMcNuts » Sun Apr 06, 2025 6:11 am
wyzxvnv wrote: Sun Apr 06, 2025 6:02 am Hello
Thank you so much
No but you could try FindVUK.
