V for Vendetta Dump submitted
Hi
Dump for MKB20_v76_V_for_Vendetta_F8D3 submitted.
Thanks.
Thanks.
Re: V for Vendetta Dump submitted
The latest KEYDB.cfg file contains these entries, which have VUKs:
0x34B4576BF1E6931C24815DD8D59C805C61D5FFC2 = V_FOR_VENDETTA (V for Vendetta) | D | 2020-08-18
0x003E4DE09EF5D2B12B541365D1B2F17765BA4E7D = V_FOR_VENDETTA (V for Vendetta) | D | 2020-09-09
0x289D8200C34207B281A1187F2D4B6C958D5F19C3 = V_FOR_VENDETTA [V for Vendetta 4K Ultra HD] | D | 2020-09-09
0xE4ADD78AD573C582EDE6BA668B36D050B5179293 = V_FOR_VENDETTA [V for Vendetta 4K Ultra HD] | D | 2020-09-09
0x518E422235F43DA7F52BE5CDF09BAA03C7CA5FA3 = V_FOR_VENDETTA (V for Vendetta) | D | 2020-08-18
0x5616CBCFF659199402F84B1415C6335AA53F98DF = V_FOR_VENDETTA (V for Vendetta) | D | 2020-09-09
Yep working now. Thanks
Mine worked without a problem but it identified two titles each of 67GB. Does anyone know if title 00 or 05 is the correct one? This is the USA WB UHD Bluray release. Thanks!
See the FAQ for "Which playlist do I choose?"
viewtopic.php?f=1&t=24388
Most of the ones I've run into have play with commentary on or off options that cause the two titles.
subsonic9701
Unable to decrypt new disc. Attaching file as instructed.
- MKB20_v76_V_FOR_VENDETTA_A42B.tgz
- (1.91 MiB) Downloaded 518 times
Habe you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?subsonic9701 wrote: ↑Mon Mar 17, 2025 8:12 pmUnable to decrypt new disc. Attaching file as instructed.
subsonic9701
Yep, that worked. Thanks!
