Penguin Series Disc 1 - 3 dump submited
ictbydesign
MKB20_v77_The_Penguin_Season_1_Disc_1_D0CE.tgz
MKB20_v77_The_Penguin_Season_1_Disc_2_CB18.tgz
MKB20_v77_The_Penguin_Season_1_Disc_3_A98E.tgz
keydb_helper
Re: Penguin Series Disc 1 - 3 dump submited
The D0CE, CB18, and A98E set of The Penguin have been added to the public keydb.ictbydesign wrote: ↑Sun Mar 16, 2025 10:41 amMKB20_v77_The_Penguin_Season_1_Disc_1_D0CE.tgz
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
ictbydesign
Thank you, sorry i did not have chance to get the other data you asked for.
I will try it later today.
ictbydesign
discs are ripping OK now.
Submitted different dumps for my copy:
MKB20_v77_The_Penguin_Season_1_Disc_1_1826
MKB20_v77_The_Penguin_Season_1_Disc_2_A462
MKB20_v77_The_Penguin_Season_1_Disc_3_66BE
KeyDB works in the meantime for them.
I wish mine would ship.
I submitted those two days ago too, but they still aren't working. Did you ever get yours to work? Usually, it works within hours of submission.
You have to use the "Synchronize" option to download the up-to-date DB file. Then re-run MakeMKV and it should work.
tulsamatthews
Anyone else still having issues with The Penguin 4K? I've manually loaded the key several times over the last couple of weeks and MKV still says the volume key is unknown on all three discs. Same dump as listed above so it should work.
The keydb definitely worked for me on all 3 discs without issue.
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?tulsamatthews wrote: ↑Tue Apr 01, 2025 2:55 amAnyone else still having issues with The Penguin 4K? I've manually loaded the key several times over the last couple of weeks and MKV still says the volume key is unknown on all three discs. Same dump as listed above so it should work.
keydb_helper
If you provide the disc dump files it shouldn't be too tricky to determine whether your particular discs should be supported by the public keydb. If they are currently supported, I'd guess you may have misplaced the keydb file or failed to unzip the downloaded file.tulsamatthews wrote: ↑Tue Apr 01, 2025 2:55 amAnyone else still having issues with The Penguin 4K? I've manually loaded the key several times over the last couple of weeks and MKV still says the volume key is unknown on all three discs. Same dump as listed above so it should work.
