MOANA 2 UHD 4K Dump File
deividcole
Moana 2 4K disc failing. Submitted dump file
- MKB20_v77_MOANA_2_4C7E.tgz
- (3.35 MiB) Downloaded 370 times
MrPenguin
Re: MOANA 2 UHD 4K Dump File
zaqqaz6917
Yes the keydb works
Bruce Leroy
Which KEYDB.cfg link worked? "keydb.cfg - Language English (28111 entries)"?
the aforementioned file link above worked. Cheers!
MrPenguin
All versions contain the same keys.Bruce Leroy wrote: Tue Mar 18, 2025 1:44 am Which KEYDB.cfg link worked? "keydb.cfg - Language English (28111 entries)"?
zaqqaz6917
The file is released nearly daily.
Just get the latest one
