Dump Submitted Throw down
The .tgz file was sent by email.
Re: Dump Submitted Throw down
What was the name of the file emailed? Posting that helps other know if they need to email their own file or not.
The DFBE variant of Throw Down has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Thank you ,I have downloaded the newest file ,but when I use MakeMKV to copy the disc, it also have previous error.keydb_helper wrote: ↑Tue Mar 11, 2025 1:17 amThe DFBE variant of Throw Down has been added to the public keydb.
You need to copy the KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.sunday46ma wrote: ↑Tue Mar 11, 2025 1:26 amThank you ,I have downloaded the newest file ,but when I use MakeMKV to copy the disc, it also have previous error.
Thank you, but I have used the xreveal instead. is it okay?MrPenguin wrote: ↑Tue Mar 11, 2025 1:31 amYou need to copy the KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.sunday46ma wrote: ↑Tue Mar 11, 2025 1:26 amThank you ,I have downloaded the newest file ,but when I use MakeMKV to copy the disc, it also have previous error.
Whatever works for yousunday46ma wrote: ↑Tue Mar 11, 2025 1:34 amThank you, but I have used the xreveal instead. is it okay?
Thank you for your patient guidance.
