Dump Submitted Throw down
sunday46ma
Post by sunday46ma » Mon Mar 10, 2025 5:21 pm
The .tgz file was sent by email.
Re: Dump Submitted Throw down
Post by dcoke22 » Mon Mar 10, 2025 9:23 pm
sunday46ma wrote: Mon Mar 10, 2025 5:21 pm The .tgz file was sent by email.
What was the name of the file emailed? Posting that helps other know if they need to email their own file or not.
sunday46ma
Post by sunday46ma » Tue Mar 11, 2025 12:05 am
dcoke22 wrote: Mon Mar 10, 2025 9:23 pm
The file name is MKB20_v77_Throw_down_DFBE.
keydb_helper
Post by keydb_helper » Tue Mar 11, 2025 1:17 am
sunday46ma wrote: Tue Mar 11, 2025 12:05 am The file name is MKB20_v77_Throw_down_DFBE.
The DFBE variant of Throw Down has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
sunday46ma
Post by sunday46ma » Tue Mar 11, 2025 1:26 am
keydb_helper wrote: Tue Mar 11, 2025 1:17 am
Thank you ,I have downloaded the newest file ,but when I use MakeMKV to copy the disc, it also have previous error.
MrPenguin
Post by MrPenguin » Tue Mar 11, 2025 1:31 am
sunday46ma wrote: Tue Mar 11, 2025 1:26 am Thank you ,I have downloaded the newest file ,but when I use MakeMKV to copy the disc, it also have previous error.
You need to copy the KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.
sunday46ma
Post by sunday46ma » Tue Mar 11, 2025 1:34 am
MrPenguin wrote: Tue Mar 11, 2025 1:31 am
Thank you, but I have used the xreveal instead. is it okay?
MrPenguin
Post by MrPenguin » Tue Mar 11, 2025 1:37 am
sunday46ma wrote: Tue Mar 11, 2025 1:34 am Thank you, but I have used the xreveal instead. is it okay?
Whatever works for you :). Xreveal also uses KEYDB.cfg, although it only needs a Unit Key rather than a Volume Unique Key.
sunday46ma
Post by sunday46ma » Tue Mar 11, 2025 1:53 am
Thank you for your patient guidance.
