Dump Submitted Throw down
sunday46ma
#1 Post by sunday46ma » Mon Mar 10, 2025 5:21 pm
The .tgz file was sent by email.
Re: Dump Submitted Throw down
#2 Post by dcoke22 » Mon Mar 10, 2025 9:23 pm
What was the name of the file emailed? Posting that helps other know if they need to email their own file or not.
sunday46ma
#3 Post by sunday46ma » Tue Mar 11, 2025 12:05 am
The file name is MKB20_v77_Throw_down_DFBE.
keydb_helper
#4 Post by keydb_helper » Tue Mar 11, 2025 1:17 am
The DFBE variant of Throw Down has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
sunday46ma
#5 Post by sunday46ma » Tue Mar 11, 2025 1:26 am
Thank you ,I have downloaded the newest file ,but when I use MakeMKV to copy the disc, it also have previous error.
MrPenguin
#6 Post by MrPenguin » Tue Mar 11, 2025 1:31 am
You need to copy the KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.
sunday46ma
#7 Post by sunday46ma » Tue Mar 11, 2025 1:34 am
Thank you, but I have used the xreveal instead. is it okay?
MrPenguin
#8 Post by MrPenguin » Tue Mar 11, 2025 1:37 am
Whatever works for you :). Xreveal also uses KEYDB.cfg, although it only needs a Unit Key rather than a Volume Unique Key.
sunday46ma
#9 Post by sunday46ma » Tue Mar 11, 2025 1:53 am
Thank you for your patient guidance.
