Dump Submitted Throw down
sunday46ma
The .tgz file was sent by email.
Re: Dump Submitted Throw down
What was the name of the file emailed? Posting that helps other know if they need to email their own file or not.
sunday46ma
The file name is MKB20_v77_Throw_down_DFBE.dcoke22 wrote: Mon Mar 10, 2025 9:23 pmWhat was the name of the file emailed? Posting that helps other know if they need to email their own file or not.
keydb_helper
The DFBE variant of Throw Down has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
sunday46ma
Thank you ,I have downloaded the newest file ,but when I use MakeMKV to copy the disc, it also have previous error.keydb_helper wrote: Tue Mar 11, 2025 1:17 amThe DFBE variant of Throw Down has been added to the public keydb.
You need to copy the KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.sunday46ma wrote: Tue Mar 11, 2025 1:26 am Thank you ,I have downloaded the newest file ,but when I use MakeMKV to copy the disc, it also have previous error.
sunday46ma
Thank you, but I have used the xreveal instead. is it okay?MrPenguin wrote: Tue Mar 11, 2025 1:31 amYou need to copy the KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.sunday46ma wrote: Tue Mar 11, 2025 1:26 am Thank you ,I have downloaded the newest file ,but when I use MakeMKV to copy the disc, it also have previous error.
Whatever works for yousunday46ma wrote: Tue Mar 11, 2025 1:34 am Thank you, but I have used the xreveal instead. is it okay?
sunday46ma
Thank you for your patient guidance.
