Wicked Part 1
leelhrsf0
Wicked Part 1
Post by leelhrsf0 »
Hi there, I keep getting a message
Has anyone else have this issue?
I have attached the tgz file
Also: Protection: AACS2.0/C v77
Thank you
MKB20_v77_Wicked_(Part_1)_6822.tgz
(3.41 MiB) Downloaded 255 times
Re: Wicked Part 1
When MakeMKV encounters a 4K UHD that it doesn't have a Hashed Key to decrypt it, MakeMKV shows that message and produces a dump file. When this happens, you should post on the forum as you've done (although the UHD discs section is more appropriate than the blu-ray discs section) and email that dump to svq@makemkv.com. Emailing the dump ensures that a hashed key will be produced.
Additionally, either attaching the file here or more preferably, putting it somewhere on the internet and posting a link to download it will help the good folks that run the alternative keydb.cfg so that a key can be added to that database of keys as well.
UHD FAQ
MrPenguin
Re: Wicked Part 1
Post by MrPenguin »
leelhrsf0 wrote: Mon Mar 10, 2025 1:41 pm Hi there, I keep getting a message
Would you also happen to have a UHD drive that isn't a Verbatim 43888 please?
