Planet Earth III (Disc II) - 4K UHD, UK Edition
Purecut
Post by Purecut » Sat Mar 09, 2024 1:44 pm
I just send the dump for Planet Earth III (4K UHD, UK Edition) for Disc II.
MKB20_v77_Planet_Earth_III_-_Disc_2_8534.tgz
The Disc II can not be decrypted. under 1.17.6
Label: Planet_Earth_III_-_Disc_2
AACS2.0/C v77
Purecut
Re: Planet Earth III (Disc II) - 4K UHD, UK Edition
Post by Purecut » Thu Mar 21, 2024 10:12 am
Working now
TwoMetreBill
Post by TwoMetreBill » Sat Mar 08, 2025 10:34 pm
Why is it working now? I can't rip:
  • Any of the Planet Earth III UHD disks
    No Time To Die UHD disk
MrPenguin
Post by MrPenguin » Sat Mar 08, 2025 10:36 pm
TwoMetreBill wrote: Sat Mar 08, 2025 10:34 pm Why is it working now? I can't rip:
TwoMetreBill
Post by TwoMetreBill » Sun Mar 09, 2025 12:28 am
Fail: MakeMKV after copying the "keydb.cfg" file causes a hard fail when restarting MakeMKV.
Rebooting MacOS fixes that problem but MakeMKV still fails on the No Time To Die UHD disk. No files saved message.
Also fails to copy the Planet Earth III disks.
So, no progress.
This reminds me of the good old days of DVDs.
Post by dcoke22 » Sun Mar 09, 2025 3:36 am
TwoMetreBill wrote: Sun Mar 09, 2025 12:28 am Fail: MakeMKV after copying the "keydb.cfg" file causes a hard fail when restarting MakeMKV.
So, no progress.
Maybe copy & paste the MakeMKV log of trying to rip Planet Earth III into a post. Failing to copy is different than failing to decrypt a disc. If we can see your log, we might be able to understand what your trouble is a little better.
TwoMetreBill
Post by TwoMetreBill » Sun Mar 09, 2025 6:23 pm
I ran Planet Earth III first and saved that log with a Planet Earth suffix. Then No Time to Die which is added to the first log. The 2nd log with the No Time to Die suffix contains both failures.
I really appreciate your help.
MakeMKV_log - Planet Earth III.txt
(61.69 KiB) Downloaded 839 times
MakeMKV_log - No Time to Die.txt
(132.61 KiB) Downloaded 874 times
MrPenguin
Post by MrPenguin » Sun Mar 09, 2025 6:56 pm
TwoMetreBill wrote: Sun Mar 09, 2025 6:23 pm I really appreciate your help.
FWIW both of your disks have complete entries in KEYDB.cfg.
Post by dcoke22 » Sun Mar 09, 2025 7:07 pm
Planet Earth III
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14131789824'
001003:0020 DEBUG: Code 1073741829 at {~MQ*yVS'VfKQ?s{:213130559
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk11' at offset '14131789824'
DEBUG: Code 1073741829 at ,NZl#*x[pz!qJ]cO^?:29394896
001003:0020 DEBUG: Code 1073741829 at ,NZl#*x[pz!qJ]cO^?:213131502
No Time to Die
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '60329164800'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk11' at offset '60329164800'
Both discs show more or less the same thing. Both discs are decrypting correctly and the rip is starting. There's a spot on the disc that the optical drive is having difficulty reading. Once it hits that spot, it can't get past it and the rip fails.
The standard advice is to gently clean the disc and try again.
TwoMetreBill
Post by TwoMetreBill » Sun Mar 09, 2025 9:22 pm
"There's a spot on the disc that the optical drive is having difficulty reading."
All 4 brand new (unopened until I removed the cellophane) disks have this same problem. There are lots of files on the disk, they all fail. It seems unlikely.
MrPenguin
Post by MrPenguin » Sun Mar 09, 2025 9:29 pm
TwoMetreBill wrote: Sun Mar 09, 2025 9:22 pm All 4 brand new (unopened until I removed the cellophane) disks have this same problem. There are lots of files on the disk, they all fail. It seems unlikely.
But still worth checking, because new disks are never guaranteed to be "pristine".
TwoMetreBill
Post by TwoMetreBill » Sun Mar 09, 2025 10:00 pm
The disks appear to be perfect. Not even a thumbprint of mine from their removal from the case.
Based on my multi-decade experience with both watching and ripping DVDs, this is an encryption problem. Vendors had their own algorithms and it would take time before the hardware would catch up. Because DVD players weren't upgradable, this meant buying a new player every couple of years.
VLC can't play the disks either, says "Your input can't be opened...." I have 3 Blu-Ray external drives, one of which is compatible with ripping Blu-Ray. They can all rip DVDs. But none can play these particular UHD/4K Blu-Ray disks. The disks play fine in my Panasonic DP-UB420-K player connected to my TV.
The Matrix Resurrections in 4K ripped just fine.
MrPenguin
Post by MrPenguin » Sun Mar 09, 2025 10:12 pm
TwoMetreBill wrote: Sun Mar 09, 2025 10:00 pm Based on my multi-decade experience with both watching and ripping DVDs, this is an encryption problem. Vendors had their own algorithms and it would take time before the hardware would catch up. Because DVD players weren't upgradable, this meant buying a new player every couple of years.
The fact that both of your disks already have entries in KEYDB means that other people have owned copies of these exact same disks for a while now. I think we'd have heard if these disks were created from an "unusual" master disk.
If cleaning your disks doesn't help then do you have a second UHD drive that you could use for comparison?
TwoMetreBill
Post by TwoMetreBill » Sun Mar 09, 2025 10:50 pm
I have 3 UHD drives. The disks can't be read with any of them. My other UHD disks read and rip fine. They can't be read with either MakeMKV or VLC.
MrPenguin
Post by MrPenguin » Sun Mar 09, 2025 11:08 pm
TwoMetreBill wrote: Sun Mar 09, 2025 10:50 pm I have 3 UHD drives. The disks can't be read with any of them. My other UHD disks read and rip fine. They can't be read with either MakeMKV or VLC.
Planet Earth III:
No Time To Die:
Can you copy /BDMV/STREAM/00018.m2ts from "Planet Earth III" or /BDMV/STREAM/00294.m2ts from "No Time To Die" from the command line? E.g.
$ cp /<mount point>/BDMV/STREAM/00018.m2ts /tmp
This test removes both MakeMKV and VLC from consideration, and checks whether even the Operating System (MacOS?) can read the disks.
