Key Add - Gorgo UHD
Fu2chN
Key Add - Gorgo UHD
#1 Post by Fu2chN » Fri Mar 07, 2025 9:34 pm
Hi, I submitted Gorgo
MKB20_v77_GORGO_UHD_D05E.tgz
It's work Now.
MrPenguin
Re: Dump Submitted - Gorgo UHD
#2 Post by MrPenguin » Sat Mar 08, 2025 12:45 am
Fu2chN wrote: Fri Mar 07, 2025 9:34 pm MKB20_v77_GORGO_UHD_D05E.tgz
Could you tell us the "last modified" date of the AACS/Unit_Key_RO.inf file on the physical UHD disk please? This value is used as the "| D |" field of a new KEYDB entry.
keydb_helper
#3 Post by keydb_helper » Sat Mar 08, 2025 3:31 am
Fu2chN wrote: Fri Mar 07, 2025 9:34 pm Hi, I submitted Gorgo
The D05E variant of Gorgo has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
