Key Add - Arcane Season 1 Disc 2 UHD
Fu2chN
Post by Fu2chN »
Hi, I submitted Arcane Season 1 Disc 2 UHD
MKB20_v77_ARCANE_SEASON_1_-_DISC_2_39BA.tgz
It's work Now.
MrPenguin
Re: Dump Submitted - Arcane Season 1 Disc 2 UHD
Post by MrPenguin »
Fu2chN wrote: Fri Mar 07, 2025 9:35 pm MKB20_v77_ARCANE_SEASON_1_-_DISC_2_39BA.tgz
Could you tell us the "last modified" date of the AACS/Unit_Key_RO.inf file on the physical UHD disk please? This value is used as the "| D |" field of a new KEYDB entry.
keydb_helper
Post by keydb_helper »
Fu2chN wrote: Fri Mar 07, 2025 9:35 pm Hi, I submitted Arcane Season 1 Disc 2 UHD
The 39BA variant of Arcane S1D2 has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
