Hi, I submitted Gorgo
MKB20_v77_GORGO_UHD_D05E.tgz
It's work Now.
Key Add - Gorgo UHD
Fu2chN
Key Add - Gorgo UHD
MrPenguin
Re: Dump Submitted - Gorgo UHD
Could you tell us the "last modified" date of the AACS/Unit_Key_RO.inf file on the physical UHD disk please? This value is used as the "| D |" field of a new KEYDB entry.
keydb_helper
The D05E variant of Gorgo has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
