Hi, I submitted Arcane Season 1 Disc 2 UHD
MKB20_v77_ARCANE_SEASON_1_-_DISC_2_39BA.tgz
It's work Now.
Key Add - Arcane Season 1 Disc 2 UHD
Re: Dump Submitted - Arcane Season 1 Disc 2 UHD
Could you tell us the "last modified" date of the AACS/Unit_Key_RO.inf file on the physical UHD disk please? This value is used as the "| D |" field of a new KEYDB entry.
keydb_helper
The 39BA variant of Arcane S1D2 has been added to the public keydb.Fu2chN wrote: Fri Mar 07, 2025 9:35 pm Hi, I submitted Arcane Season 1 Disc 2 UHD
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
