Gladiator II Dump Submitted
Greetings,
MKB20_v77_Gladiator_II_AAFC
I also shared the file on Google Drive for KeyDB.
Regards,
Regards,
Re: Gladiator II Dump Submitted
Hi, i Submitted a dump for:
MKB20_v77_Gladiator_II_307E
Submitted MKB20_v77_Gladiator_II_56FC.tgz
- MKB20_v77_Gladiator_II_307E.tgz
- (3.37 MiB) Downloaded 702 times
Try downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MAkeMKV also writes its TGZ dump files) and restarting MakeMKV.
Got the latest KEYDB.cfg. Still does not work for me.
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=896BE8641F13)
Saved AACS dump file as C:\Users\Antognini/.MakeMKV/MKB20_v77_Gladiator_II_56FC.tgz
Based on the current posts, it does not look like 56FC has been added yet. It was mentioned that AAFC was ready. We will need to wait for 56FC to be decrypted and added to the KeyDBFireMeUp84 wrote: ↑Fri Mar 07, 2025 8:02 pmGot the latest KEYDB.cfg. Still does not work for me.
It´s working now (_307E). Even without using the key.db procedure.
Thank you.
Thank you.
I just ran MakeMKV. It downloaded "latest HK," seems to be working.
New dump submitted.
MKB20_v77_Gladiator_II_98BF
KeyDB works in the meantime.
