Help with Drive Options
webdweeb
Post by webdweeb »
I am a recent lurker on the forum and have a question regarding 4 drives I currently own: Pioneer BDR-D207DBK (firmware 1.21, in OWC USB 2.0/FW 400/800/eSATA ext case), Pioneer BDR-209DBK (firmware 1.10, in OWC USB 2.0/FW 400/800/eSATA ext case), Asus BW-16D1HT (bare drive, unknown FW, build date on drive is 2018-05-15), Pioneer BDR-XD05S (firmware 3.01, Pioneer external USB 3.0 case). I recall reading that the Asus is flashable to allow read/write of UHD 4k disks, but I am unsure of the options for the other three drives. I am the original owner for all 4 drives, none of which have had their original firmware flashed. I have successfully used the 207 and 209 drives in the past to rip and burn double layer blurays and DVDs, SACD-Rs (using single layer DVD-Rs), DVD-Audio, standard single layer Blu-rays, along with Redbook CDs, but I am unsure if any of the Pioneer drives can be flashed to allow ripping or burning of higher capacity discs (4k, BDXL, etc). I've seen a couple of older threads that mention the 209D, but not the 207D, but I was unclear as to the post-flash capability of the drive, hence my question
Thanks for any input on my drive options.
webdweeb
Re: Help with Drive Options
Post by webdweeb »
A bit more relevant info: the Pioneer BDR-XD05S has a build date of August 2016, and the Asus BW-16D1HT has a firmware version of 3.03
webdweeb wrote: Thu Mar 06, 2025 10:11 pm I am a recent lurker on the forum and have a question regarding 4 drives I currently own: Pioneer BDR-D207DBK (firmware 1.21, in OWC USB 2.0/FW 400/800/eSATA ext case), Pioneer BDR-209DBK (firmware 1.10, in OWC USB 2.0/FW 400/800/eSATA ext case), Asus BW-16D1HT (bare drive, unknown FW, build date on drive is 2018-05-15), Pioneer BDR-XD05S (firmware 3.01, Pioneer external USB 3.0 case). I recall reading that the Asus is flashable to allow read/write of UHD 4k disks, but I am unsure of the options for the other three drives. I am the original owner for all 4 drives, none of which have had their original firmware flashed. I have successfully used the 207 and 209 drives in the past to rip and burn double layer blurays and DVDs, SACD-Rs (using single layer DVD-Rs), DVD-Audio, standard single layer Blu-rays, along with Redbook CDs, but I am unsure if any of the Pioneer drives can be flashed to allow ripping or burning of higher capacity discs (4k, BDXL, etc). I've seen a couple of older threads that mention the 209D, but not the 207D, but I was unclear as to the post-flash capability of the drive, hence my question
Post the MakeMKV drive info & libredrive info sections for all of your drives. Then we can help further.
webdweeb
Post by webdweeb »
Here is the info for the Asus:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.03
Serial number: xxxx
Firmware date: 2118-01-19 15:58
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 3.03
webdweeb wrote: Fri Mar 07, 2025 12:18 am Here is the info for the Asus:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.03
Serial number: xxxx
That one can easily be flashed. Just use the SDFtool Flasher viewtopic.php?p=94848#p94848 and either firmware BW-16D1HT 3.10-MK or WH16NS60 1.02-MK (recommended)
Post the info for the Pioneer drives.
webdweeb
Post by webdweeb »
I am on a Mac, which can be problematic for firmware updates on certain devices. I have an older Intel Mini with VMware Fusion running Windows 7, as well as a newer M1 MacBook Pro with Windows 11 (ARM CPU version)-any idea if either of these would be suitable to flash the firmware?
webdweeb wrote: Fri Mar 07, 2025 2:11 am I am on a Mac, which can be problematic for firmware updates on certain devices. I have an older Intel Mini with VMware Fusion running Windows 7, as well as a newer M1 MacBook Pro with Windows 11 (ARM CPU version)-any idea if either of these would be suitable to flash the firmware?
I don't know for sure. I do know that it doesn't work via parallels and any other VM can also be an issue. An actual Windows 10 or 11 PC is best.
You could use the command line on Mac and do the flash that way.
viewtopic.php?p=74718#p74718 about 2/3rds the way down the first post. Look for heading: How To Flash Videos and commands
webdweeb
Post by webdweeb »
Thanks-I will take a look at the terminal command line option, which is probably my only option unless I can find a friend with a PC that can help me do the flashing.
BTW, here is the info for the Pioneer slim drive:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: xxxx
Firmware date: 2014-12-26
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
webdweeb
Post by webdweeb »
Number 3, Pioneer BDR-209DBK (in an OWC external case):
Product: BD-RW BDR-209D
Revision: 1.10
Serial number: xxxx
Firmware date: 2013-09-10
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.10/ID61
My fourth drive, the PIONEER BDR-207DBK, is bare and needs to be mounted in the OWC case, so I will post the particulars once I do that.
webdweeb wrote: Fri Mar 07, 2025 3:27 am Number 3, Pioneer BDR-209DBK (in an OWC external case):
Revision: 1.10
Serial number: xxxx
the 207 cant be done
the others can email me for the pioneer flasher if you want it
see below
webdweeb
Post by webdweeb »
Billycar11, thanks for chiming in. Does your flasher work on a Mac, or will I have to use the Terminal as I do with the Asus drive? Also, does each Pioneer drive require a tailored flasher? Thanks again for the input!
webdweeb
Post by webdweeb »
So I take it the BDR-207D max disc capacity is a double layer Bluray, correct? It's been awhile since I did any BD burns on either of the 5.25" Pioneers, but I am pretty sure I was able to do a DL BD disc on the 207 (or I might be thinking of the 209!). That one has a sticky tray anyway, so maybe it is time to send it to the great disc drive farm in the sky.
webdweeb wrote: Fri Mar 07, 2025 4:11 am Billycar11, thanks for chiming in. Does your flasher work on a Mac, or will I have to use the Terminal as I do with the Asus drive? Also, does each Pioneer drive require a tailored flasher? Thanks again for the input!
windows only use vms at your own risk
webdweeb
Post by webdweeb »
Ok, thanks-maybe I can find another forum member with the same MacOS restriction and see how they handled it. Or I could just bite the bullet and get myself a low end PC for the various utilities that are Windows-specific. I have a similar challenge with programming some older URC universal remotes (wanted a Harmony, but Logitech pulled the plug on that option), as that SW also runs only on a PC, and a lot of the other disc and media manipulation SW also prefers the Windows environment.
webdweeb wrote: Fri Mar 07, 2025 4:27 am Ok, thanks-maybe I can find another forum member with the same MacOS restriction and see how they handled it. Or I could just bite the bullet and get myself a low end PC for the various utilities that are Windows-specific. I have a similar challenge with programming some older URC universal remotes (wanted a Harmony, but Logitech pulled the plug on that option), as that SW also runs only on a PC, and a lot of the other disc and media manipulation SW also prefers the Windows environment.
Those that only have access to Mac use terminal to flash their drives. It's not hard. The Ultimate Guide 2025 even has the command for you. Just edit the drive and firmware paths.
