Mandalorian S1 D2 2025 Re-Release
guardion
Post by guardion »
Hey,
Disc 1 worked fine, Disc 2 can't be decrypted
I already tried the public DB and sent an email to svq@
Dump is attached
MrPenguin
Re: Mandalorian S1 D2 2025 Re-Release
Post by MrPenguin »
guardion wrote: Sun Mar 02, 2025 5:08 pm Disc 1 worked fine, Disc 2 can't be decrypted
Have you tried refreshing your KEYDB.cfg file? It is updated regularly...
guardion
Post by guardion »
MrPenguin wrote: Mon Mar 03, 2025 11:29 am
Yes, I also said that in my original post :)
mine is updated nightly automatically via systemd timer
MrPenguin
Post by MrPenguin »
guardion wrote: Mon Mar 03, 2025 11:32 am Yes, I also said that in my original post :)
Yes, but it's possible that KEYDB has been updated since that time ;)
guardion wrote: Mon Mar 03, 2025 11:32 am mine is updated nightly automatically via systemd timer
And does it work now...?
guardion
Post by guardion »
nope, otherwise I would’ve said so
Your posts are not really helpful for me, to be honest
MrPenguin
Post by MrPenguin »
guardion wrote: Mon Mar 03, 2025 3:25 pm Your posts are not really helpful for me, to be honest
Hmm, that's odd. I suspect you're doing something wrong then, but I won't trouble you further.
guardion wrote: Mon Mar 03, 2025 3:25 pm nope, otherwise I would’ve said so
There is a key available since today. And you could be a bit friendlier.
guardion
Post by guardion »
Coopervid wrote: Mon Mar 03, 2025 4:15 pm
I kind of figured that after his last post. I tried to not be rude, which obviously still came out wrong. I'll try to be better next time!
MrPenguin wrote: Mon Mar 03, 2025 4:12 pm
Sorry about that, I downloaded the DB already 5 times today, hence my reaction after you pointing it out again and me posting initially that I am using the latest available. To me your post just didn't seem helpful because of that.
Whoever added the key to the DB of you guys, thanks a lot. It's working now.
I didn't add it and if you are on Windows just use the synchronize feature instead of downloading the whole DB over and over again.
To automate it for Makemkv read this:
viewtopic.php?f=12&t=32784
