Hey,
Disc 1 worked fine, Disc 2 can't be decrypted
I already tried the public DB and sent an email to svq@
Dump is attached
Mandalorian S1 D2 2025 Re-Release
MrPenguin
Re: Mandalorian S1 D2 2025 Re-Release
Have you tried refreshing your KEYDB.cfg file? It is updated regularly...
guardion
Yes, I also said that in my original post
mine is updated nightly automatically via systemd timer
MrPenguin
Yes, but it's possible that KEYDB has been updated since that time
And does it work now...?
guardion
nope, otherwise I would’ve said so
Your posts are not really helpful for me, to be honest
MrPenguin
Hmm, that's odd. I suspect you're doing something wrong then, but I won't trouble you further.
There is a key available since today. And you could be a bit friendlier.guardion wrote: Mon Mar 03, 2025 3:25 pm nope, otherwise I would’ve said so
guardion
I kind of figured that after his last post. I tried to not be rude, which obviously still came out wrong. I'll try to be better next time!
Sorry about that, I downloaded the DB already 5 times today, hence my reaction after you pointing it out again and me posting initially that I am using the latest available. To me your post just didn't seem helpful because of that.
Whoever added the key to the DB of you guys, thanks a lot. It's working now.
I didn't add it and if you are on Windows just use the synchronize feature instead of downloading the whole DB over and over again.
To automate it for Makemkv read this:
viewtopic.php?f=12&t=32784
