Dump Submitted - Wicked Part 1
Re: Dump Submitted - Wicked Part 1
MKB20_v77_WICKED_PART_1_C0F4.tgz sent from an LG Drive (FWIW a couple of days ago).
Any chance of uploading this dump here as an attachment please?
Here is a MKB20_v77_WICKED_PART_1_11BA dump from a LG BU40N if someone needs it.
Edit: Delete after it was added! Thanks keydb_helper
keydb_helper
Thank you for the disc dump. The 11BA variant of Wicked Part 1 has been added to the public keydb.
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Sorry, it's been a while since I submitted one (it was via e-mail).
File Deleted
Submitting via email is still the right thing to do for MakeMKV's hashed key process. Attaching the dump here or posting a download link is also good for the alternative keydb process.
keydb_helper
Thank you for providing a disc dump file. The C0F4 variant of Wicked Part 1 has been added to the public keydb.
Please try again with the latest public keydb agentbrowderagentbrowder wrote: ↑Wed Feb 26, 2025 2:52 amMKB20_v77_Wicked_(Part_1)_C0F4.tgz
Tried the latest KEYDB.cfg file - no luck.
agentbrowder
Works now - thank you.keydb_helper wrote: ↑Sat Mar 01, 2025 1:16 amPlease try again with the latest public keydb agentbrowder
I was able to successfully rip my copy: https://thediscdb.com/movie/wicked-2024 ... es/2025-4k
Emailed MKB20_v77_Wicked_(Part_1)_6822.tgz
It's been updated in the keydb. Just grab a new copy of the keydb and extract it to the MakeMKV data directory and you're good to go.
BaronVonRuthless
I'm also unable to open my copy: UK Universal release. Emailed over MKB20_v77_Wicked_(Part_1)_6822.tgz
Tried manually downloading and extracting the keydb and it doesn't look like it's there yet.
Have you copied the KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarted MakeMKV?BaronVonRuthless wrote: ↑Wed Mar 12, 2025 4:51 pmTried manually downloading and extracting the keydb and it doesn't look like it's there yet.
Trust me, it's in there.
That's the disc id that corresponds to it. If you're having trouble and are on windows, my tool can help:
viewtopic.php?f=12&t=16883&p=166510#p166510
0xA1B41230C864AB707382109C647B54BE1C3EF793
BaronVonRuthless
Sorry for not responding; I've been away. Can confirm I extracted to the correct location and restarted, but I didn't retry/reconfirm and I haven't tried the tool! I'll try again and confirm. Thanks for the replies!
