The Running Man
The Running Man
Current profile: BD-R SRM
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: ...
Highest AACS version: 81
Firmware version: 1.05
Disc Information
Label: RUNNING_MAN
Timestamp: 2022-08-30 15:18:40
Protection: AACS2.0/C v77
Data capacity: 57.22 Gb
Bus encryption flags: 80
Revision: 1.05
Serial number: ...
Disc Information
Label: RUNNING_MAN
Re: The Running Man
updated firmware in drive to wh16ns60 1.00 3 trying again sent unziped zip file to sqv could not locate file any inf files? not sure what . look at all files with notepad most were scrambled dat file. old guy working here so a little slow had to download some ware to unzip tgz files
Re: The Running Man
mr penguin, unable to reply to message as new user with zero access , the data file is correct only 56 byte the zipped fille adds to it
Re: The Running Man
The AACS/MKB_RO.inf file is on the physical UHD disk. It's also quite big, so zipping is advised...Back_up_AZ wrote: ↑Fri Feb 28, 2025 11:34 pmupdated firmware in drive to wh16ns60 1.00 3 trying again sent unziped zip file to sqv could not locate file any inf files? not sure what . look at all files with notepad most were scrambled dat file. old guy working here so a little slow had to download some ware to unzip tgz files
You don't need to unzip the TGZ file, btw. I think the point is that the AACS/MKB_RO.inf file inside the TGZ file is "wrong", and so people need to see what the original AACS/MKB_RO.inf file from the physical disk looks like.
Re: The Running Man
updated firmware on drive
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: M00M7PA0346
Firmware date: 2120-05-08 10:10
Firmware version: 1.03
Disc Information
Label: RUNNING_MAN
Revision: 1.03
Disc Information
Label: RUNNING_MAN
Re: The Running Man
attempting to open takes a lot longer than it did previous i will let it run all night to see what happens and will upload dump to https://gofile.io/d/FlaraA
Re: The Running Man
Thank you for providing the disc dump and full MKB_RO file. The 8FC5 variant of The Running Man has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
