Dump Submitted - Wicked Part 1
jmone
Re: Dump Submitted - Wicked Part 1
Post by jmone »
MKB20_v77_WICKED_PART_1_C0F4.tgz sent from an LG Drive (FWIW a couple of days ago).
MrPenguin
Post by MrPenguin »
jmone wrote:
Fri Feb 28, 2025 8:50 am
Any chance of uploading this dump here as an attachment please?
NGNXM8
Post by NGNXM8 »
Here is a MKB20_v77_WICKED_PART_1_11BA dump from a LG BU40N if someone needs it.
Edit: Delete after it was added! Thanks keydb_helper :)
keydb_helper
Post by keydb_helper »
NGNXM8 wrote:
Fri Feb 28, 2025 1:29 pm
Thank you for the disc dump. The 11BA variant of Wicked Part 1 has been added to the public keydb.
Public KeyDB Disc Submissions
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
jmone
Post by jmone »
MrPenguin wrote:
Fri Feb 28, 2025 11:55 am
Sorry, it's been a while since I submitted one (it was via e-mail).
File Deleted
jmone wrote:
Fri Feb 28, 2025 8:15 pm
Submitting via email is still the right thing to do for MakeMKV's hashed key process. Attaching the dump here or posting a download link is also good for the alternative keydb process.
keydb_helper
Thank you for providing a disc dump file. The C0F4 variant of Wicked Part 1 has been added to the public keydb.
agentbrowder wrote:
Wed Feb 26, 2025 2:52 am
MKB20_v77_Wicked_(Part_1)_C0F4.tgz
Tried the latest KEYDB.cfg file - no luck.
Please try again with the latest public keydb agentbrowder
agentbrowder
Post by agentbrowder »
keydb_helper wrote:
Sat Mar 01, 2025 1:16 am
Works now - thank you.
lfoust
Post by lfoust »
I was able to successfully rip my copy: https://thediscdb.com/movie/wicked-2024 ... es/2025-4k
Xeonian
Post by Xeonian »
Emailed MKB20_v77_Wicked_(Part_1)_6822.tgz
Post by SamuriHL »
It's been updated in the keydb. Just grab a new copy of the keydb and extract it to the MakeMKV data directory and you're good to go.
BaronVonRuthless
Post by BaronVonRuthless »
I'm also unable to open my copy: UK Universal release. Emailed over MKB20_v77_Wicked_(Part_1)_6822.tgz
Tried manually downloading and extracting the keydb and it doesn't look like it's there yet.
MrPenguin
Post by MrPenguin »
BaronVonRuthless wrote:
Wed Mar 12, 2025 4:51 pm
Have you copied the KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarted MakeMKV?
Post by SamuriHL »
Trust me, it's in there.
0xA1B41230C864AB707382109C647B54BE1C3EF793
That's the disc id that corresponds to it. If you're having trouble and are on windows, my tool can help:
viewtopic.php?f=12&t=16883&p=166510#p166510
BaronVonRuthless
Sorry for not responding; I've been away. Can confirm I extracted to the correct location and restarted, but I didn't retry/reconfirm and I haven't tried the tool! I'll try again and confirm. Thanks for the replies!
