Demolition Man Dump Submitted
Ralph P.
Post by Ralph P. »
Greetings,
MKB20_v77_DEMOLITION_MAN_-_4K_UHD_F420
I have also uploaded the dump file to Google Drive for KeyDB access. I will PM the link.
Regards,
keydb_helper
Re: Demolition Man Dump Submitted
Post by keydb_helper »
Ralph P. wrote:
Tue Dec 03, 2024 12:12 pm
Greetings,
Regards,
The F420 variant of Demolition Man has been added to the public keydb.
Public KeyDB Disc Submissions
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Ralph P.
Post by Ralph P. »
keydb_helper wrote:
Wed Dec 11, 2024 2:59 am
Greetings,
Regards,
Greetings,
It is ripping now. Thank you!
RenDan
Post by RenDan »
How can I get this?
I've downloaded the keydb from Find VUK online database, and also used the Find VUK tool, but neither have the F420 variant.
Thanks.
Post by SamuriHL »
If you're on windows, you can try my tool here:
viewtopic.php?p=166510#p166510
See if that helps.
RenDan
Post by RenDan »
Thanks, I gave it a go and still not working.
I appear to have two issues:
1. my Asus drive doesn't always recognise it. When it does, it's only in Mac OS, not Windows, and when MakeMKV isn't running. I saw on another post to load the disc, before starting MakeMKV, let the OS recognise the disc then start MakeMKV
2. When Mac OS does recognise the disc and I start MakeMKV, it has the disc information, and then problems arise when I try to either create an MKV file or create a backup. Other posts have listed the issues.
I've run KeyDB Helper today to download the latest keyed.cfg file. Looking through the keys for Demolition Man, there's only one key for UHD, and it doesn't match Ralph P's posted on 3rd December 2024 " MKB20_v77_DEMOLITION_MAN_-_4K_UHD_F420".
I'd like to get a hold of that key to give it a go. If it doesn't work with that, then at least I can write it off as a bad disc.
keydb_helper
RenDan wrote:
Thu Feb 27, 2025 6:41 pm
Ralph P. wrote:
Wed Dec 11, 2024 1:17 pm
Greetings,
The F420 variant of Demolition Man has been supported by the public keydb since December 10. Ralph has previously confirmed that the public keydb supported his F420 disc variant. It has the libaacs disc ID value of 0xA5B046B47E0145AAAFFFFEC8FFEEEE23957950B1.
RenDan
Post by RenDan »
Thanks for confirming.
I almost gave up, but gave it one last try and was able to backup the disc, and then make the MKV file, after.
Friggingrease
Post by Friggingrease »
I'm currently having this issue with TWO discs of Demolition Man. One is the Limited Edition from Arrow Video, the other standard. makemkv recognizes the disc, but when I try to run it to rip, it just spits debug codes at me. This also happens for both standard editions of Conan the Barbarian and Destroyer, as well as Basketcase, but I did sucessfully rip Basketcase once. And I can't again. Sometimes I get read errors, sometimes key exchange failures.
I've download the sdf.bin file manually. Is Demolition Man still giving people issues?
My Drive is the ASUS BW-16D1HT flashed to the 3.10 with Java and Libredrive active. It works with so many other discs. A quirk here is, this doesn't reliably dump .tgz files. When a 4k disc fails, my drive goes into sleep mode and I have to reset.
Edit: I did get a .tgz file generated and have e-mailed it. The variant at the end was F421, not F420 like mentioned in this thread
Friggingrease
I did end up getting a .tgz file submitted to the e-mail, the variant at the end was F421, not F420. That could be the issue?
Friggingrease wrote:
Thu Nov 13, 2025 12:06 pm
Check out the hashed keys section of the UHD FAQ
MrPenguin
Post by MrPenguin »
Tue Nov 11, 2025 11:07 pm
IEdit: I did get a .tgz file generated and have e-mailed it. The variant at the end was F421, not F420 like mentioned in this thread
These two variants are actually the same disk. However, the F421 tgz dump file will contain a truncated MKB_RO.inf file, whereas the F420 dump will contain the disk's complete MKB_RO.inf file.
It seems odd that MakeMKV would be creating a F421 dump when someone has already submitted a F420 one. Has your UHD drive enabled LibreDrive?
Friggingrease
Yeah it is Libre enabled. It's an Asus BW-16D1HT, flashed to 3.10. Most discs run fine, these two Demolition Man's (1 Limited Edition and one not), Basket Case (Have ripped once before, can't repeat), Conan the Destroyer and Barbarian all act the same. They get hung up on contenthash002.tbl, then start spitting debug codes before I get some read errors, key exchange errors, and one says the license was revoked by my drive. Funny enough these are all Arrow Video UHDs, and I believe AACS 2.0 /v77.
I can't reliably get a .tgz file to get dumped into the folder for some reason.
