Deadpool and Wolverine
curiouscaterpie
Post by curiouscaterpie »
Hi all,
I sent an email to svq@makemkv.com for Deadpool and Wolverine 07FA on Jan 27. I tried again today and it's showing the key is unknown. My program preferences allow internet access to download the new keys. I'm not sure if the email was missed or how long it typically takes to generate a key, but figured it probably is best to provide it here as well. Dump files are attached.
-curiouscaterpie
MrPenguin
Re: Deadpool and Wolverine 07FA Dump
Post by MrPenguin »
curiouscaterpie wrote: Wed Feb 26, 2025 10:12 pm I sent an email to svq@makemkv.com for Deadpool and Wolverine 07FA on Jan 27. I tried again today and it's showing the key is unknown. My program preferences allow internet access to download the new keys. I'm not sure if the email was missed or how long it typically takes to generate a key, but figured it probably is best to provide it here as well. Dump files are attached.
curiouscaterpie
This worked, thanks for your help! It's odd that the key files didn't pull even with the checkbox selected. I even updated to the latest version but still had the same issue. I'm glad to see it can be manually updated.
curiouscaterpie wrote: Sun Mar 02, 2025 2:32 am
Which checkbox?? You need to run FindVUK-Synchronize.bat from time to time. To automate it for Makemkv read this:
viewtopic.php?f=12&t=32784
