Report back how it went. Glad to have you brought on the right path.PCGold wrote: Tue Feb 25, 2025 8:00 pm Thanks a ton. Looks like it was already live and could have found this but did not. Sorry about that... I ran searches and likely was just buried in more info that I am only beginning to grasp. As an IT person we cannot know all so love the help from the experts with experience.
I look forward to setting up my Plex server with ripped data... Wife will be shocked at all this...quite easy really![]()
ASUS BW-16D1X-U - Flashable?
Re: ASUS BW-16D1X-U - Flashable?
Both BIN files produce Error coves too long to copy...ideas?
Use SDFToolFlasher. I think you are on Windows.
You don't copy the bin files. Download Marty's SDFtool Flasher and either "All you need software pack" to your windows computer. Unzip the pack if needed and then start the SDFtool Flasher program and select the firmware to write with that tool.
Crisslayer
hi @Coopervid can also pm ing to additional details to flash my drive to UHD, i have the same drive and the same drive information, thx for your attention.Coopervid wrote: Tue Feb 25, 2025 11:06 amPM is coming.audiosync wrote: Mon Feb 24, 2025 10:32 pm@Coopervid, would you mind pm'ing me with the necessary additional details to flash? I have the SDFtool flasher (v1.3.5), the ASUS_ODD_FW_Changer_(Modified) (24.08.2019), and the following firmware which I could flash (ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin). As you're aware, the SDFtool flasher doesn't work, as it's not the MT1959 platform.
Should I utilize the ASUS_ODD_FW_Changer? Wanted to make sure I didn't update it to one of the latest firmware's, and then not be able to go back.
Really would appreciate your insight. Cheers
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: ...
Firmware date: 2015-10-20
Drive platform: RS8600
Firmware version: E101/ID76
To play it safe I need you to post your own Makemkv information.Crisslayer wrote: Thu Feb 27, 2025 9:15 amhi @Coopervid can also pm ing to additional details to flash my drive to UHD, i have the same drive and the same drive information, thx for your attention.Coopervid wrote: Tue Feb 25, 2025 11:06 amPM is coming.audiosync wrote: Mon Feb 24, 2025 10:32 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: ...
Crisslayer
Good morning this is my information.Coopervid wrote: Thu Feb 27, 2025 3:49 pmTo play it safe I need you to post your own Makemkv information.Crisslayer wrote: Thu Feb 27, 2025 9:15 amhi @Coopervid can also pm ing to additional details to flash my drive to UHD, i have the same drive and the same drive information, thx for your attention.
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: ......
Highest AACS: 68
Good. PM is coming.Crisslayer wrote: Thu Feb 27, 2025 4:18 pmGood morning this is my information.Coopervid wrote: Thu Feb 27, 2025 3:49 pmTo play it safe I need you to post your own Makemkv information.Crisslayer wrote: Thu Feb 27, 2025 9:15 am
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Highest AACS: 68
Colectionaru
Hi, I'm new around here so bear with my lack of knowledge please >,<
I bought a few years ago a Blu-Ray Writer from ASUS, model "BW-16D1X-U" and mainly used it to burn single layer BD-R discs or read DVDs (close to 100 discs done).
First thing I noticed about it is that it gets quite hot while burning the BD-R discs and reading DVDs, my guess would be the laser being too powerful. As such I'm worried in the long term if it will damage itself.
Until now my solution was to have a 20 min pause between burning discs, but I would really like to know if flashing the firmware to the lastest available or to a modified one would solve my issue here, because being able to burn discs head to head would speed up my workload by a ton.
From what I've read in this thread, I need to provide here the MakeMKV information of the drive:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: ***********
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
Disc Information
Label: ***********
Timestamp: ***********
Data capacity: 19.56 Gb
Disc type: BD-R
Number of layers: 1
If I need to provide some other information about the drive I'll see to it as fast as I can.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Disc Information
Label: ***********
Disc type: BD-R
Number of layers: 1
I doubt a firmware update would make any difference with regards to writing discs. It's normal for a drive to warm up as it is doing a lot of work. Just leave the tray open for 5 mins after writing a disc before moving on to the next one. This gives you a few minutes to grab a cuppa or go to the loo!Colectionaru wrote: Wed Mar 12, 2025 1:00 am Hi, I'm new around here so bear with my lack of knowledge please >,<
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Disc Information
Label: ***********
Disc type: BD-R
Number of layers: 1
Just so you know, this drive is flashable to enable libredrive and UHD support if you want it.
Colectionaru
I see, that's too bad. So I guess I have one more room heater now alongside my GPU ˙ ͜ʟ˙MartyMcNuts wrote: Wed Mar 12, 2025 2:30 am I doubt a firmware update would make any difference with regards to writing discs. It's normal for a drive to warm up as it is doing a lot of work. Just leave the tray open for 5 mins after writing a disc before moving on to the next one. This gives you a few minutes to grab a cuppa or go to the loo!
And if it's flashable, having it support UHD would be a plus so I want that for sure anyway!
I've done a bit of reading in the "Ultimate UHD Drives Flashing Guide Updated 2025" and "SDFtool Flasher" threads which were mentioned here so I don't start asking useless questions before informing myself on the situation and what I understood is that I can use that tool to flash the drive to version 3.10?
Also, I'm a bit confused considering the drives which is that version from are "BW-16D1H-U" and "BW-16D1H-U Pro", not from a newer "BW-16D1X-U" than mine.
That's my biggest worry, if it could brick the drive by loading firmware from another model.
Thanks for the fast reply by the way, I was expecting one til' the end of the week but not so soon >,<
I've heard various reports than BW-16D1HT 3.10-MK works fine on your drive model. The most recent: viewtopic.php?p=169224#p169224Colectionaru wrote: Wed Mar 12, 2025 2:49 amI see, that's too bad. So I guess I have one more room heater now alongside my GPU ˙ ͜ʟ˙MartyMcNuts wrote: Wed Mar 12, 2025 2:30 am I doubt a firmware update would make any difference with regards to writing discs. It's normal for a drive to warm up as it is doing a lot of work. Just leave the tray open for 5 mins after writing a disc before moving on to the next one. This gives you a few minutes to grab a cuppa or go to the loo!
As long as you only use 25GB discs you are fine and you shouldn't worry too much about the drive warming up. A 50GB disc is a different animal and especially LG / ASUS drives are not the best burners for those. If you burn them use this method.Colectionaru wrote: Wed Mar 12, 2025 2:49 amI see, that's too bad. So I guess I have one more room heater now alongside my GPU ˙ ͜ʟ˙MartyMcNuts wrote: Wed Mar 12, 2025 2:30 am I doubt a firmware update would make any difference with regards to writing discs. It's normal for a drive to warm up as it is doing a lot of work. Just leave the tray open for 5 mins after writing a disc before moving on to the next one. This gives you a few minutes to grab a cuppa or go to the loo!
- Spare_area.zip
- (339.2 KiB) Downloaded 1823 times
Unless I've misread this thread, this new old stock drive I picked up should be flashable. I'm unsure of the next steps, as I've only previously dealt with LG drives. Any help would be appreciated.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: ************
Firmware date: 2017-12-21
Highest AACS version: 81
Drive platform: RS8601
Firmware version: E111/ID76
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
sure just email me for the flasher see below for emailpolargeek wrote: Thu Mar 13, 2025 9:08 pm Unless I've misread this thread, this new old stock drive I picked up should be flashable. I'm unsure of the next steps, as I've only previously dealt with LG drives. Any help would be appreciated.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
