Dump submitted for all 3 films in trilogy:
MKB20_v77_Paddington_2EF4
MKB20_v77_Paddington_2_8408
MKB20_v77_Paddington_In_Peru_B460
Dump Submitted Paddington Trilogy
Re: Dump Submitted Paddington Trilogy
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?gelsthorpei wrote: ↑Mon Feb 17, 2025 12:00 pmDump submitted for all 3 films in trilogy:
MasterRipper8
I have just downloaded the latest keydb.cfg file (LastUpdate: 2025-02-17 22:50:05) and it is not yet working for all three discs.
keydb_helper
If you would like to see your Paddington discs supported by the public keydb, I'd recommend providing links to the disc dump files.MasterRipper8 wrote: ↑Mon Feb 17, 2025 10:03 pmI have just downloaded the latest keydb.cfg file (LastUpdate: 2025-02-17 22:50:05) and it is not yet working for all three discs.
Public KeyDB Disc Submissions
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Could you upload your dumps here as attachments please? Or maybe upload them into (say) Google Drive or OneDrive, and then reply with download links? It's possible that The Powers That KeyDB may then be able to add these disks to KEYDB.MasterRipper8 wrote: ↑Mon Feb 17, 2025 10:03 pmI have just downloaded the latest keydb.cfg file (LastUpdate: 2025-02-17 22:50:05) and it is not yet working for all three discs.
gelsthorpei
keydb_helper
Could you please enable public access to all three dump files? Unfortunately they are not currently accessiblegelsthorpei wrote: ↑Tue Feb 18, 2025 1:27 pmHere are the three dumps:
https://drive.google.com/file/d/1_6i-pG ... drive_link
https://drive.google.com/file/d/1aG9T23 ... drive_link
https://drive.google.com/file/d/15KRtdk ... drive_link
keydb_helper
The 2EF4, 8408 and B460 variants of Paddington, Paddington 2 and Paddington in Peru have been added to the public keydbgelsthorpei wrote: ↑Mon Feb 17, 2025 12:00 pmDump submitted for all 3 films in trilogy:
MasterRipper8
Thank you! Downloading now and will give it a test!
keydb_helper wrote: ↑Tue Feb 18, 2025 3:41 pmThe 2EF4, 8408 and B460 variants of Paddington, Paddington 2 and Paddington in Peru have been added to the public keydbgelsthorpei wrote: ↑Mon Feb 17, 2025 12:00 pmDump submitted for all 3 films in trilogy:
Dump submitted for Paddington 2 from the trilogy.
MKB20_v77_Paddington_2_BB02.tgz
