Dump Submitted Paddington Trilogy
gelsthorpei
Post by gelsthorpei » Mon Feb 17, 2025 12:00 pm
Dump submitted for all 3 films in trilogy:
MKB20_v77_Paddington_2EF4
MKB20_v77_Paddington_2_8408
MKB20_v77_Paddington_In_Peru_B460
MrPenguin
Re: Dump Submitted Paddington Trilogy
Post by MrPenguin » Mon Feb 17, 2025 3:33 pm
MasterRipper8
Post by MasterRipper8 » Mon Feb 17, 2025 10:03 pm
I have just downloaded the latest keydb.cfg file (LastUpdate: 2025-02-17 22:50:05) and it is not yet working for all three discs.
keydb_helper
Post by keydb_helper » Tue Feb 18, 2025 12:00 am
If you would like to see your Paddington discs supported by the public keydb, I'd recommend providing links to the disc dump files.
Public KeyDB Disc Submissions
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
MrPenguin
Post by MrPenguin » Tue Feb 18, 2025 12:01 am
Could you upload your dumps here as attachments please? Or maybe upload them into (say) Google Drive or OneDrive, and then reply with download links? It's possible that The Powers That KeyDB may then be able to add these disks to KEYDB.
keydb_helper
Post by keydb_helper » Tue Feb 18, 2025 2:08 pm
Could you please enable public access to all three dump files? Unfortunately they are not currently accessible
keydb_helper
Post by keydb_helper » Tue Feb 18, 2025 3:41 pm
The 2EF4, 8408 and B460 variants of Paddington, Paddington 2 and Paddington in Peru have been added to the public keydb
MasterRipper8
Post by MasterRipper8 » Tue Feb 18, 2025 7:57 pm
Thank you! Downloading now and will give it a test!
m3gtgfx
Post by m3gtgfx » Wed Mar 19, 2025 4:39 pm
Dump submitted for Paddington 2 from the trilogy.
MKB20_v77_Paddington_2_BB02.tgz
