command for lg slim bp60nb10 svc code nb12 on windows powershell 86
Luckkyfox
#1 Post by Luckkyfox » Sun Feb 16, 2025 8:35 pm
it keeps on saying Internal error 0x83000001
the code I'm putting in is .\makemkvcon64.exe f --all-yes -d E: rawflash enc -i 'C:\Users\Billy\Downloads\Downgrade-Enabled-Firmware\Auto-Flash\LG-Desktop-NB10-sleep-fix\HL-DT-ST-BD-RE_BP60NB10-NB12-1.02-N000300-212107081556.bin'
i could be overlooking a bunch of stuff but idk what to do put
MrPenguin
Re: command for lg slim bp60nb10 svc code nb12 on windows powershell 86
#2 Post by MrPenguin » Sun Feb 16, 2025 10:41 pm
Luckkyfox wrote: Sun Feb 16, 2025 8:35 pm it keeps on saying Internal error 0x83000001
Random thought: Does your PC use an Intel CPU or an AMD CPU?
Luckkyfox
#3 Post by Luckkyfox » Sun Feb 16, 2025 10:53 pm
MrPenguin wrote: Sun Feb 16, 2025 10:41 pm
intel why?
MrPenguin
#4 Post by MrPenguin » Sun Feb 16, 2025 11:14 pm
Luckkyfox wrote: Sun Feb 16, 2025 10:53 pm intel why?
I was wondering whether the EXE used any Intel-specific CPU instructions, meaning it would fail to run on an AMD CPU.
Luckkyfox
#5 Post by Luckkyfox » Mon Feb 17, 2025 1:06 am
MrPenguin wrote: Sun Feb 16, 2025 11:14 pm
how could i find out if it does any intel-specific instructions?
#6 Post by MartyMcNuts » Mon Feb 17, 2025 1:59 am
I think you have to use "quotes" around the path. Also, are you sure that path is correct?
You know, it'd probably be so much easier to use SDFTool Flasher.
Luckkyfox
#7 Post by Luckkyfox » Mon Feb 17, 2025 2:15 am
MartyMcNuts wrote: Mon Feb 17, 2025 1:59 am
using quotes gives the same error also not fully sure i believe it should be the right path
using SDFTool Flasher gives me a error code 0x82052603
#8 Post by MartyMcNuts » Mon Feb 17, 2025 2:27 am
Luckkyfox wrote: Mon Feb 17, 2025 2:15 am
Are you sure that is the correct firmware?? I believe the correct firmware should have an "M" after the "N" as in BP60NB10-NB12-1.02-NM00300.
If your BP60NB10 is a SVC NB12, try grabbing my firmware pack in the SDFtool Flasher thread (first post, same place you got the flasher from) as it contains the DE_LG_BP60NB10-NB12_1.02-MK.bin firmware file.
In SDFtool Flasher, you should also see 2 green "check marks", for both Drive Platform and Encrypted Firmware.
Luckkyfox
#9 Post by Luckkyfox » Mon Feb 17, 2025 3:21 am
MartyMcNuts wrote: Mon Feb 17, 2025 2:27 am
ok the "M" after the "N" didn't work but i went back to the firmware pack & tried the 1.02 version instead of 1.00/1.01 & IT WORKED /it fully downloaded then i tried burning a dvd
it said "failed to open disc" went back to SPFTool flasher now its there's a X on the encrypted firmware
Luckkyfox
#10 Post by Luckkyfox » Mon Feb 17, 2025 3:24 am
its error code 0xff056103 also thanks for the help
#11 Post by MartyMcNuts » Mon Feb 17, 2025 3:40 am
Luckkyfox wrote: Mon Feb 17, 2025 3:21 am
No, you can't just change it to a M, I meant if it didn't have the M in it, is was the wrong firmware. MK firmware has been edited to allow flashing and downgrading and enables libredrive. You must flash the drive with a MK firmware, which is why I suggested using the DE_LG_BP60NB10-NB12_1.02-MK.bin firmware file from my firmware pack.
So where are you actually at now? Is the drive flashed correctly? Show your MakeMKV drive and libredrive info.
#12 Post by MartyMcNuts » Mon Feb 17, 2025 3:42 am
Luckkyfox wrote: Mon Feb 17, 2025 3:24 am
Make sure there is no disc in the drive and the tray is closed.
Luckkyfox
#13 Post by Luckkyfox » Mon Feb 17, 2025 4:20 am
MartyMcNuts wrote: Mon Feb 17, 2025 3:40 am
where can i use/find ur firmware pack ?
#14 Post by dcoke22 » Mon Feb 17, 2025 4:26 am
Luckkyfox wrote: Mon Feb 17, 2025 4:20 am where can i use/find ur firmware pack ?
See the first post in MartyMcNuts's SDFtool Flasher thread: https://forum.makemkv.com/forum/viewtopic.php?f=16&t=22896
Luckkyfox
#15 Post by Luckkyfox » Mon Feb 17, 2025 5:18 am
dcoke22 wrote: Mon Feb 17, 2025 4:26 am
it went thru again still isn't letting me burn things says the same thing about the disc
