it keeps on saying Internal error 0x83000001
the code I'm putting in is .\makemkvcon64.exe f --all-yes -d E: rawflash enc -i 'C:\Users\Billy\Downloads\Downgrade-Enabled-Firmware\Auto-Flash\LG-Desktop-NB10-sleep-fix\HL-DT-ST-BD-RE_BP60NB10-NB12-1.02-N000300-212107081556.bin'
i could be overlooking a bunch of stuff but idk what to do put
command for lg slim bp60nb10 svc code nb12 on windows powershell 86
Luckkyfox
MrPenguin
Re: command for lg slim bp60nb10 svc code nb12 on windows powershell 86
Random thought: Does your PC use an Intel CPU or an AMD CPU?
Luckkyfox
MrPenguin
I was wondering whether the EXE used any Intel-specific CPU instructions, meaning it would fail to run on an AMD CPU.
Luckkyfox
I think you have to use "quotes" around the path. Also, are you sure that path is correct?Luckkyfox wrote: Sun Feb 16, 2025 8:35 pm it keeps on saying Internal error 0x83000001
You know, it'd probably be so much easier to use SDFTool Flasher.
Luckkyfox
using quotes gives the same error also not fully sure i believe it should be the right pathMartyMcNuts wrote: Mon Feb 17, 2025 1:59 amI think you have to use "quotes" around the path. Also, are you sure that path is correct?Luckkyfox wrote: Sun Feb 16, 2025 8:35 pm it keeps on saying Internal error 0x83000001
using SDFTool Flasher gives me a error code 0x82052603
Are you sure that is the correct firmware?? I believe the correct firmware should have an "M" after the "N" as in BP60NB10-NB12-1.02-NM00300.Luckkyfox wrote: Mon Feb 17, 2025 2:15 amusing quotes gives the same error also not fully sure i believe it should be the right pathMartyMcNuts wrote: Mon Feb 17, 2025 1:59 amI think you have to use "quotes" around the path. Also, are you sure that path is correct?Luckkyfox wrote: Sun Feb 16, 2025 8:35 pm it keeps on saying Internal error 0x83000001
If your BP60NB10 is a SVC NB12, try grabbing my firmware pack in the SDFtool Flasher thread (first post, same place you got the flasher from) as it contains the DE_LG_BP60NB10-NB12_1.02-MK.bin firmware file.
In SDFtool Flasher, you should also see 2 green "check marks", for both Drive Platform and Encrypted Firmware.
Luckkyfox
ok the "M" after the "N" didn't work but i went back to the firmware pack & tried the 1.02 version instead of 1.00/1.01 & IT WORKED /it fully downloaded then i tried burning a dvdMartyMcNuts wrote: Mon Feb 17, 2025 2:27 amAre you sure that is the correct firmware?? I believe the correct firmware should have an "M" after the "N" as in BP60NB10-NB12-1.02-NM00300.Luckkyfox wrote: Mon Feb 17, 2025 2:15 amusing quotes gives the same error also not fully sure i believe it should be the right pathMartyMcNuts wrote: Mon Feb 17, 2025 1:59 am
it said "failed to open disc" went back to SPFTool flasher now its there's a X on the encrypted firmware
Luckkyfox
its error code 0xff056103 also thanks for the helpMartyMcNuts wrote: Mon Feb 17, 2025 2:27 amAre you sure that is the correct firmware?? I believe the correct firmware should have an "M" after the "N" as in BP60NB10-NB12-1.02-NM00300.Luckkyfox wrote: Mon Feb 17, 2025 2:15 amusing quotes gives the same error also not fully sure i believe it should be the right pathMartyMcNuts wrote: Mon Feb 17, 2025 1:59 am
No, you can't just change it to a M, I meant if it didn't have the M in it, is was the wrong firmware. MK firmware has been edited to allow flashing and downgrading and enables libredrive. You must flash the drive with a MK firmware, which is why I suggested using the DE_LG_BP60NB10-NB12_1.02-MK.bin firmware file from my firmware pack.Luckkyfox wrote: Mon Feb 17, 2025 3:21 amok the "M" after the "N" didn't work but i went back to the firmware pack & tried the 1.02 version instead of 1.00/1.01 & IT WORKED /it fully downloaded then i tried burning a dvdMartyMcNuts wrote: Mon Feb 17, 2025 2:27 amAre you sure that is the correct firmware?? I believe the correct firmware should have an "M" after the "N" as in BP60NB10-NB12-1.02-NM00300.Luckkyfox wrote: Mon Feb 17, 2025 2:15 am
So where are you actually at now? Is the drive flashed correctly? Show your MakeMKV drive and libredrive info.
Make sure there is no disc in the drive and the tray is closed.Luckkyfox wrote: Mon Feb 17, 2025 3:24 amits error code 0xff056103 also thanks for the helpMartyMcNuts wrote: Mon Feb 17, 2025 2:27 amAre you sure that is the correct firmware?? I believe the correct firmware should have an "M" after the "N" as in BP60NB10-NB12-1.02-NM00300.Luckkyfox wrote: Mon Feb 17, 2025 2:15 am
Luckkyfox
where can i use/find ur firmware pack ?MartyMcNuts wrote: Mon Feb 17, 2025 3:40 amNo, you can't just change it to a M, I meant if it didn't have the M in it, is was the wrong firmware. MK firmware has been edited to allow flashing and downgrading and enables libredrive. You must flash the drive with a MK firmware, which is why I suggested using the DE_LG_BP60NB10-NB12_1.02-MK.bin firmware file from my firmware pack.Luckkyfox wrote: Mon Feb 17, 2025 3:21 amok the "M" after the "N" didn't work but i went back to the firmware pack & tried the 1.02 version instead of 1.00/1.01 & IT WORKED /it fully downloaded then i tried burning a dvdMartyMcNuts wrote: Mon Feb 17, 2025 2:27 am
See the first post in MartyMcNuts's SDFtool Flasher thread: https://forum.makemkv.com/forum/viewtopic.php?f=16&t=22896
Luckkyfox
it went thru again still isn't letting me burn things says the same thing about the discdcoke22 wrote: Mon Feb 17, 2025 4:26 amSee the first post in MartyMcNuts's SDFtool Flasher thread: https://forum.makemkv.com/forum/viewtopic.php?f=16&t=22896
