I have this Ocean's Trilogy . I had no issues with Twelve or Thirteen, but I cannot get the main title from Eleven to rip. I have ripped the extras from that disc without issue, but anytime I try to rip either of the 2 movie tracks it gets stuck at 817.9mb and then has problems until it cancels out. I've made sure the disc is clean. Checked the laser lens for dust. Still has a problem at the same exact spot every time.
Here's my log file:
Ocean's Eleven issues
MrPenguin
Re: Ocean's Eleven issues
Have you also tried copying the "main title" file manually, e.g. from Windows File Explorer? The copied file will obviously still be bus-encrypted, but you will discover whether even your OS can read the disk.
The last time something like that happened to me, I needed to return the disk to Amazon for a replacement.
dfoles
It won’t copy past 1% and just trying to watch it regularly in MakeMKV from the disc it froze at 1:59. Looks like I’ll have to reach out to Amazon or WB.MrPenguin wrote: Sun Feb 09, 2025 9:38 pmHave you also tried copying the "main title" file manually, e.g. from Windows File Explorer? The copied file will obviously still be bus-encrypted, but you will discover whether even your OS can read the disk.
