Pioneer BDR-XD08UMB-S -- SLOW
etyrnal
Post by etyrnal »
First blu-ray drive. Is it just me, or does blu-ray take FOREVER compared to dvd??
mac mini m4 pro
brand new Pioneer BDR-XD08UMB-S
read 1.7x
says it's going to take 7 hours??
Is this normal?? The disc surface looks absolutely perfect.
MakeMKV v1.17.8 darwin(arm64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-XD08U 1.02 CHDL003299UCd" opened in OS access mode.
File 00107.mpls was added as title #0
File 00002.mpls was added as title #1
File 00106.mpls was added as title #2
File 00101.mpls was added as title #3
File 00105.mpls was added as title #4
Title #00002.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00015.m2ts was added as title #5
Title #00014.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00074.m2ts was added as title #6
File 00009.m2ts was added as title #7
Title #00007.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.m2ts was added as title #8
Title #00004.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/bloop/Movies/Scurmuffle
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '19367522304'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '19367522304'
Re: Pioneer BDR-XD08UMB-S -- SLOW
Errors like this:
indicate that the drive is having trouble correctly reading spots on the disc. MakeMKV will retry reads until it either gets a correct read or the retry limit is reached.
The standard advice is to gently clean the disc.
nothingworks
Post by nothingworks »
dcoke22 wrote:
Tue Jan 28, 2025 7:27 pm
Errors like this:
Is there anything to do if cleaning the disc doesn’t work?
MrPenguin
Post by MrPenguin »
nothingworks wrote:
Sat Feb 08, 2025 9:29 pm
The Pioneer XD08U is a high-quality drive. However, the usual steps would be:
  1. Try a different disk in your XD08U, to check whether MakeMKV can read it. (This should confirm your drive is OK.)
  2. Try the disk in a different drive, or maybe even a dedicated UHD player (if you have one).
  3. Replace the disk.
  4. Sacrifice a ripe mango to Cthulhu.
etyrnal
Post by etyrnal »
it was a brand new disk out of the package -- untouched by human hands.
etyrnal wrote:
Wed Dec 24, 2025 11:15 pm
So most likely needs a thorough clean with soapy water. Brand new out of the box is when most discs need to be cleaned due to often having an invisible layer of gunk on them from the manufacturing process.
