Dump Submitted The Wicker Man
ukconfederate
MKB20_v70_The_Wicker_Man_-_Disc_1_6081
I downloaded the latest KEYDB.cfg but this didn't work either.
It's only disc 1 of the 2 disc set that doesn't work, the one with The Final Cut on it.
keydb_helper
Re: Dump Submitted The Wicker Man
In order for your disc to be added to the public keydb, you would probably need to provide the disc dump file either as an attachment or a link to a file host. Please note that disc dumps from LG/Asus drives are the preferred option for this purpose.ukconfederate wrote: Thu Feb 06, 2025 6:07 pm MKB20_v70_The_Wicker_Man_-_Disc_1_6081
If the disc dump produced by MakeMKV is a 'partial' dump (smaller than 1MB), you would also need to zip up and include the AACS folder from the disc.
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
ukconfederate
Thank you for your reply.keydb_helper wrote: Thu Feb 06, 2025 8:33 pmIn order for your disc to be added to the public keydb, you would probably need to provide the disc dump file either as an attachment or a link to a file host. Please note that disc dumps from LG/Asus drives are the preferred option for this purpose.ukconfederate wrote: Thu Feb 06, 2025 6:07 pm MKB20_v70_The_Wicker_Man_-_Disc_1_6081
Here's the link to the MakeMKV MKB20_v70_The_Wicker_Man_-_Disc_1_6081 Dump tgz file (File generated from an ASUS DVD Drive).
Here's the link to the AACS zip file as the dump file is less than a MB.
Hopefully this will help.
keydb_helper
Thanks for following my instructions. Unfortunately, neither of your links can be downloaded. Could you please enable public access to those two Google Drive links?ukconfederate wrote: Fri Feb 07, 2025 12:55 pm Thank you for your reply.
ukconfederate
This is now sorted and should be downloadable.keydb_helper wrote: Fri Feb 07, 2025 1:03 pm
My apologies for this, I completely forgot about giving the download permission.
Your disc is in the keydb with disc id
if you're on windows you can use my tool to sync the keydb. Found here: viewtopic.php?f=12&t=16883&p=166510#p166510
0xACBA001EF328E8FFFEAF5A6FAC9C1B434FFC56F5
ukconfederate
Hi,SamuriHL wrote: Fri Feb 07, 2025 4:50 pm Your disc is in the keydb with disc id
if you're on windows you can use my tool to sync the keydb. Found here: viewtopic.php?f=12&t=16883&p=166510#p166510Code: Select all
Sadly, this hasn't helped, I still get the "The volume key is unknown for this disc - video can't be decrypted. Failed to open disc" and then produces the tgz dump file.
I have downloaded the latest KEYDB.cfg file, when that didn't work I then followed the instructions to download and use the software you linked to. It downloaded and installed the keydb file again but alas, it still will not work.
Thank you for taking the time to help me though.
Run findvuk's validatedisc command on that disc then.
Replace X with the drive letter for the disc.
findvuk.exe /ValidateDisc /Drive=X
ukconfederate
Unfortunately that didn't work either.SamuriHL wrote: Sat Feb 08, 2025 3:53 pm Run findvuk's validatedisc command on that disc then.
Replace X with the drive letter for the disc.Code: Select all
I've attached a screenshot of shot the info it produced.
MrPenguin
Odd... Does your new TGZ dump file contain a file called kv.dat? And if so, how big is it? In your original TGZ dump file, the kv.dat was only 68 bytes long, which is suspiciously small.ukconfederate wrote: Sat Feb 08, 2025 2:49 pm Sadly, this hasn't helped, I still get the "The volume key is unknown for this disc - video can't be decrypted. Failed to open disc" and then produces the tgz dump file.
MrPenguin
You also need to add this setting to your FindVUK.ini file:
Disable_Bus_Encryption_Cmd = "C:\Program Files (x86)\MakeMKV\makemkvcon.exe" info dev:$DRIVE$-
ukconfederate
MrPenguin wrote: Sat Feb 08, 2025 4:39 pmOdd... Does your new TGZ dump file contain a file called kv.dat? And if so, how big is it? In your original TGZ dump file, the kv.dat was only 68 bytes long, which is suspiciously small.ukconfederate wrote: Sat Feb 08, 2025 2:49 pm Sadly, this hasn't helped, I still get the "The volume key is unknown for this disc - video can't be decrypted. Failed to open disc" and then produces the tgz dump file.
MrPenguin wrote: Sat Feb 08, 2025 4:41 pmYou also need to add this setting to your FindVUK.ini file:Assuming that is where you have installed MakeMKV.Code: Select all
The new dump file still only produced a file size of 1KB.
I added the above line to the .ini file which allowed more information to be produced which I've quoted below.
Unfortunately, the disc still won't copy.
17:26:12 - Validation successful! UnitKeys are valid!!
17:26:12 - MediaKey and VolumeID match VUK!
17:26:12 - -------------------------------------------------------
17:26:12 - MetaTitle : The Wicker Man - Disc 1
17:26:12 - VolumeName : THE_WICKER_MAN_DISC1
17:26:12 - DiscID : ACBA001EF328E8FFFEAF5A6FAC9C1B434FFC56F5
17:26:12 - DateDiscID : 2023-07-07
17:26:12 - DiscType : UHD
17:26:12 - VUK : DF34E0255D3C0CB18584EA2C3FD1416A
17:26:12 - MEDIAKEY : 61A3F9A0E25A75AB26F194769D2C9292
17:26:12 - VOLUMEID : 29719A32719961405B09774E856FF6A1
17:26:12 - >>> UnitKeyDEC (1) >8B52D7279B1A2F73995AED2A5D089160< (Unused)
17:26:12 - MKBrev : 70
17:26:12 - BusEncrEn : 1
17:26:12 - AACS : 1
17:26:12 - BD+ : 0
17:26:12 - --- Write entry in main-keydb file ---
17:26:12 - Keys in Keyfile: 161304 keys - KeyFile: C:\Users\x\AppData\Roaming\aacs\KEYDB.cfg
17:26:12 - Disc with ID >ACBA001EF328E8FFFEAF5A6FAC9C1B434FFC56F5< is already in file - need to compare the details
17:26:12 - KEYDB: Identical entry already present in keydb-file
17:26:12 - >> Identical: TITLE, VUK, DATE, MEDIAKEY, VOLUMEID, UNITKEYS, COMMENT - Different: nothing >> will NOT write new entry in keydb-file
17:26:12 - Identical entry already present in keydb-file - file is not changed
17:26:12 - --- Write entry in backup-keydb file ---
17:26:12 - Keys in Keyfile: 1 keys - KeyFile: C:\Users\x\Documents\KeyDB_Helper_1.0.0.2\FindVUK\VUKbackup\KEYDB.cfg
17:26:12 - --- Upload MetaXML to OnlineDB file ---
Establishing connection
HTTP-POST success
17:26:13 - Successfully posted to the OnlineDB! >
Preconditions fulfilled - process upload now
Detected BlurayMetaXML - DiscId >ACBA001EF328E8FFFEAF5A6FAC9C1B434FFC56F5<
Upload written to database!
Meta-Upload successfully processed!
17:26:13 - Successful upload to OnlineDB
17:26:13 - Eject the disc now from drive >E:\<
17:26:17 - Successfully ejected the media in drive E!
17:26:17 - Eject disc from drive >E< - insert next disc to validate or exit with ESC
17:26:17 - Eject the disc now from drive >E:\<
MrPenguin
That's to be expected. Can you see the size of the kv.dat file inside this new TGZ dump file?ukconfederate wrote: Sat Feb 08, 2025 5:32 pm The new dump file still only produced a file size of 1KB.
This means that the KEYDB entry for your disk has now been proved to be correct. I can only assume that the KEYDB.cfg file inside your MakeMKV data directory (which is where MakeMKV also writes its TGZ dump files) has not been updated. Note that you also need to restart MakeMKV after updating the KEYDB.cfg file.ukconfederate wrote: Sat Feb 08, 2025 5:32 pm I added the above line to the .ini file which allowed more information to be produced which I've quoted below.
------------------------------------------------------------------------------- 17:26:12 - Validation successful! UnitKeys are valid!! ------------------------------------------------------------------------------- ... 17:26:12 - MediaKey and VolumeID match VUK!
ukconfederate
I have the latest KEYDB.cgf file in the folder where the TGZ dump files are written to. I even restarted my PC and changed to my backup DVD drive too (different make), but it still continues to fail.MrPenguin wrote: Sat Feb 08, 2025 6:21 pmThat's to be expected. Can you see the size of the kv.dat file inside this new TGZ dump file?ukconfederate wrote: Sat Feb 08, 2025 5:32 pm The new dump file still only produced a file size of 1KB.This means that the KEYDB entry for your disk has now been proved to be correct. I can only assume that the KEYDB.cfg file inside your MakeMKV data directory (which is where MakeMKV also writes its TGZ dump files) has not been updated. Note that you also need to restart MakeMKV after updating the KEYDB.cfg file.ukconfederate wrote: Sat Feb 08, 2025 5:32 pm I added the above line to the .ini file which allowed more information to be produced which I've quoted below.
Thanks again for everyone trying to help me. I just don't know what I'm doing wrong with this disc, first one that's stumped me.
I don't know. My tool definitely puts the keydb in the proper folder as it reads the registry value for MakeMKV's data directory to find it. It doesn't "guess". I've never had a disc that has a keydb entry with a VUK not work in MakeMKV.
