Dump Submitted: Twin Peaks Z to A UHD disc
cartload88
Post by cartload88 » Tue Feb 04, 2025 2:22 am
MKB20_v72_Twin_Peaks_From_Z_to_A_E01D.tgz
MrPenguin
Re: Dump Submitted: Twin Peaks Z to A UHD disc
Post by MrPenguin » Tue Feb 04, 2025 3:06 pm
cartload88 wrote: Tue Feb 04, 2025 2:22 am MKB20_v72_Twin_Peaks_From_Z_to_A_E01D.tgz
cartload88
Post by cartload88 » Tue Feb 04, 2025 5:10 pm
I just tried and no change:
MakeMKV v1.17.9 win(x64-release) started
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Saved AACS dump file as C:\Users\bcarter/.MakeMKV/MKB20_v72_Twin_Peaks_From_Z_to_A_E01D.tgz
MrPenguin
Post by MrPenguin » Tue Feb 04, 2025 9:33 pm
cartload88 wrote: Tue Feb 04, 2025 5:10 pm I just tried and no change:
Could you perhaps upload this TGZ dump file into (say) Google Drive or OneDrive, and then post a link here please? It's possible that The Powers That KEYDB might be able to help while MakeMKV also examines your dump.
cartload88
Post by cartload88 » Tue Feb 04, 2025 9:49 pm
Please see the link... and thanks!!!
https://drive.google.com/file/d/15FD1z5 ... sp=sharing
babypuncher
Post by babypuncher » Tue Feb 04, 2025 11:47 pm
MrPenguin wrote: Tue Feb 04, 2025 9:33 pm Could you perhaps upload this TGZ dump file into (say) Google Drive or OneDrive, and then post a link here please? It's possible that The Powers That KEYDB might be able to help while MakeMKV also examines your dump.
Not OP, but I have the same disc. Here's the dump: https://drive.google.com/file/d/1Ckd67i ... sp=sharing
keydb_helper
Post by keydb_helper » Wed Feb 05, 2025 12:02 am
babypuncher wrote: Tue Feb 04, 2025 11:47 pm Not OP, but I have the same disc. Here's the dump: https://drive.google.com/file/d/1Ckd67i ... sp=sharing
Thanks for the partial disc dump. Could you please also zip up the 'AACS' folder from your disc and provide a link?
Public KeyDB Disc Submissions
briansemerick
Post by briansemerick » Wed Feb 05, 2025 1:01 am
I emailed my dump zip as well. It's weird because this is just a repress of the one from a couple years ago, which I assumed was already cracked.
babypuncher
Post by babypuncher » Wed Feb 05, 2025 1:16 am
keydb_helper wrote: Wed Feb 05, 2025 12:02 am Thanks for the partial disc dump. Could you please also zip up the 'AACS' folder from your disc and provide a link?
Sure thing! https://drive.google.com/file/d/1CDpoEv ... sp=sharing
keydb_helper
Post by keydb_helper » Wed Feb 05, 2025 1:37 am
briansemerick wrote: Wed Feb 05, 2025 1:01 am I emailed my dump zip as well. It's weird because this is just a repress of the one from a couple years ago, which I assumed was already cracked.
When MakeMKV generates a 'partial' dump file (~100KB instead of 3-5MB) it does seem to indicate that the disc shares a key with a known title. I believe that is the case for this disc.
cartload88 wrote: Tue Feb 04, 2025 9:49 pm Please see the link... and thanks!!!
babypuncher wrote: Wed Feb 05, 2025 1:16 am Sure thing!
Thank you both for making the required details available to the forum. The E01D disc variant has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
cartload88
Post by cartload88 » Wed Feb 05, 2025 12:58 pm
And thank you for the quick turnaround. Y’all are the very best!
briansemerick
Post by briansemerick » Wed Feb 05, 2025 10:02 pm
thank you!!
theffx
Post by theffx » Wed Feb 12, 2025 4:50 am
My UHD disc was using MKB20_v72_Twin_Peaks_From_Z_to_A_326D.tgz which I just submitted via email. This wasn't in the latest keydb file that I downloaded a couple hours ago.
keydb_helper
Post by keydb_helper » Wed Feb 12, 2025 10:41 am
theffx wrote: Wed Feb 12, 2025 4:50 am My UHD disc was using MKB20_v72_Twin_Peaks_From_Z_to_A_326D.tgz which I just submitted via email. This wasn't in the latest keydb file that I downloaded a couple hours ago.
If you would like to see the public keydb support your particular disc, you will probably need to provide a link to your disc dump file and the AACS folder from your disc. Otherwise you'll have to wait several days or weeks for native MakeMKV support.
