Dump Submitted: Twin Peaks Z to A UHD disc
cartload88
MKB20_v72_Twin_Peaks_From_Z_to_A_E01D.tgz
Re: Dump Submitted: Twin Peaks Z to A UHD disc
cartload88
I just tried and no change:
MakeMKV v1.17.9 win(x64-release) started
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Saved AACS dump file as C:\Users\bcarter/.MakeMKV/MKB20_v72_Twin_Peaks_From_Z_to_A_E01D.tgz
Could you perhaps upload this TGZ dump file into (say) Google Drive or OneDrive, and then post a link here please? It's possible that The Powers That KEYDB might be able to help while MakeMKV also examines your dump.
cartload88
babypuncher
Not OP, but I have the same disc. Here's the dump: https://drive.google.com/file/d/1Ckd67i ... sp=sharing
keydb_helper
Thanks for the partial disc dump. Could you please also zip up the 'AACS' folder from your disc and provide a link?babypuncher wrote: ↑Tue Feb 04, 2025 11:47 pmNot OP, but I have the same disc. Here's the dump: https://drive.google.com/file/d/1Ckd67i ... sp=sharing
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
briansemerick
I emailed my dump zip as well. It's weird because this is just a repress of the one from a couple years ago, which I assumed was already cracked.
babypuncher
Sure thing! https://drive.google.com/file/d/1CDpoEv ... sp=sharingkeydb_helper wrote: ↑Wed Feb 05, 2025 12:02 amThanks for the partial disc dump. Could you please also zip up the 'AACS' folder from your disc and provide a link?
keydb_helper
When MakeMKV generates a 'partial' dump file (~100KB instead of 3-5MB) it does seem to indicate that the disc shares a key with a known title. I believe that is the case for this disc.briansemerick wrote: ↑Wed Feb 05, 2025 1:01 amI emailed my dump zip as well. It's weird because this is just a repress of the one from a couple years ago, which I assumed was already cracked.
Thank you both for making the required details available to the forum. The E01D disc variant has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
cartload88
And thank you for the quick turnaround. Y’all are the very best!
briansemerick
thank you!!
My UHD disc was using MKB20_v72_Twin_Peaks_From_Z_to_A_326D.tgz which I just submitted via email. This wasn't in the latest keydb file that I downloaded a couple hours ago.
keydb_helper
If you would like to see the public keydb support your particular disc, you will probably need to provide a link to your disc dump file and the AACS folder from your disc. Otherwise you'll have to wait several days or weeks for native MakeMKV support.
