Issues With Verbatim 43888
olePigeon
#1 Post by olePigeon » Tue Feb 04, 2025 2:09 am
Hello.
I purchased MakeMKV and a Verbatim 43888 4K UHD drive under the impression that it would work out of the box to back up some of my Blu-Rays. It worked fine for regular Blu-Rays, but when I got to my first 4K UHD, it wouldn't work. This particular Blu-Ray is 4K UHD only, it doesn't come with a regular Blu-Ray version, otherwise I wouldn't bother.
I get a string of errors about how the disc can't be decrypted. I tried the different options for macOS V2 Key bug, but none of the made a difference.
I did a search of the forums, but I couldn't find an solution that didn't require direct messaging.
I'm using my registered copy of MakeMKV version 1.17.8 on macOS Sequoia 15.1.1. The internet option is checkboxed. Below is the drive info, and attached is the debug information. Thank you for any help.
OS device name: /dev/rdisk4
Product: BD-RE BU40N
Revision: 1.05
Serial number: ...
Highest AACS version: 72
Re: Issues With Verbatim 43888
#2 Post by d00zah » Tue Feb 04, 2025 1:58 pm
Until recently, this drive came w/ a Pioneer drive, which worked 'out of the box'. The BD-RE BU40N, which is now showing up in this assembly more often, requires flashing a patched FW,
Per the Ultimate UHD Drives Flashing Guide Updated 2025:
BU40N on any Firmware directly to > BU40N 1.03MK
file: HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
using the procedure detailed in the 'Mac/linux commands to flash' section of the 1st post.
If you are uncomfortable with the command line, SDFtool Flasher from a friend's Windows PC is MUCH simpler. YMMV
MrPenguin
#3 Post by MrPenguin » Tue Feb 04, 2025 3:22 pm
Revision: 1.05
Serial number: ...
Your current TGZ dump file isn't usable because LibreDrive has not been enabled. When you have successfully flashed your drive to enable LibreDrive, could you then attach any new TGZ dump file that MakeMKV creates please?
olePigeon
#4 Post by olePigeon » Tue Feb 04, 2025 5:13 pm
Thank you everyone. As this was my first post it had to be approved first. Shortly after I sent the post for review, I found the 2025 Blu-Ray Flash guide with everything I needed. Coupled with Shutter Encoder, I'm able to make quick work backing up my discs.
It would appear that my Verbatim 43888 shipped with the BU40N drive instead of the other one that's already supported. I had to use the Flash utility to upgrade the firmware. After doing that, everything worked perfectly. The USB-C version of this drive is extremely fast. I can backup a regular Blu-Ray on my Mac in just a few minutes.
As a side note for anyone else that may have had the same disconnect issue I was having: This drive appears to work fine. I had gone through half a dozen generic drives trying to get one to work, and they would all disconnect at random whenever I tried to backup a Blu-Ray. This would happen on both my Mac and my PC, even when I use a PD port or powered USB hub.
I bought this Verbatim because the pictures on Amazon showed it had an auxiliary power port, and it appeared to be compatible with MakeMKV. However, when I received it, it didn't have the power port. Amazon also changed the pictures to reflect that. So I guess it's an updated design. I have not had any connection issues, however. It would appear Verbatim uses a proper USB-C connector that allows it to pull more than 5v, eliminating the disconnect issue I was having.
kaister
#5 Post by kaister » Tue Feb 04, 2025 8:49 pm
Where did you get the Verbatim 43888?
I see people saying to get it from Amazon Germany so I simply assume all 43888 from other regions are now on BU40N drive instead of the Pioneer UD04 drive that works out of the box.
But I'm wondering whether those from Germany are switching over to the BU40N yet.
olePigeon
#6 Post by olePigeon » Wed Feb 05, 2025 6:42 pm
I bought the U.S. version on Amazon.
kaister
#7 Post by kaister » Thu Feb 06, 2025 7:20 pm
Ah got it. Thanks.
THe BU40N is kinda surprising to me. It actually better than I thought. I'm not sure how well it'll hold up in the long run. I suspect Verbatim probably couldn't secure any more Pioneer drive so they have to settle for the second best drive they can get their hands on. Based on the little experience I have with it, it doesn't really lose out much compare to the pioneer drive. I think the pioneer is still a little more quite but in terms of ripping, they're pretty comparable as far as I can tell.
snowcold
#8 Post by snowcold » Mon Feb 10, 2025 10:16 pm
Just a friendly reminder for all my fellow Aussies. I recently bought a similar drive from Officeworks, and my unit came with a LG Drive too.
Dragolution
#9 Post by Dragolution » Sat Oct 04, 2025 1:10 pm
I also have the 43888 version and I’m trying to back up the movie with my drive. The program shows me:
Drive platform: RS8A10
Firmware version: 1.14
So far everything looks fine.
Then I start the backup with “decrypt” and it takes about 1 hour 30 minutes. In the end I get a message saying that one file failed the hash check – and of course it’s the main movie file.
My question is: What am I doing wrong, or where is the issue?
#10 Post by MartyMcNuts » Sun Oct 05, 2025 2:10 am
Are there any errors in the log window?
In any case, what you should do:
1. Clean the disc.
2. Ensure the drive is getting enough constant power. Use USB ports direct from the motherboard (USB-C if possible), or use an AC self powered hub (30w+). Don't use case ports.
Dragolution
#11 Post by Dragolution » Sun Oct 05, 2025 9:31 am
Thx for the reply :)
Yeah I guess its the disc. Fesh out of the box and did not work.
Tried another one. Works.
#12 Post by MartyMcNuts » Sun Oct 05, 2025 11:46 pm
Often, fresh out of the box discs require cleaning as they can contain an invisible film on them from the manufacturing process.
fox87
#13 Post by fox87 » Fri Oct 10, 2025 6:47 pm
hello sirs and madames of the blueray backup scene,
i am new to this forum. please be kind.
sorry for waking the dead. this thread seems quite old but it was the one fitting closest i guess.
I am using the Verbatim with the Pioneer Drive, fw 1.14 from 2020, which is supposed to run in makemkv out of the box and it kinda is. even 4k bluerays seem to run...until i tried 3d bds. there i always run into some kind of hardware error at some point. i tried two movies and had the same issue.
is there anything i can do to fix that?
thanks in advance.
Greetings fox
#14 Post by dcoke22 » Sat Oct 11, 2025 12:48 pm
MakeMKV can rip 3D blu-rays successfully. Anyone have 3D movie success?
Perhaps copy & paste your MakeMKV log from a failed 3D blu-ray rip attempt. That way someone can help you understand what the failure is and maybe how to fix it.
