old pioneer fw is LibreDrive ENABLEDhiddenvalley700 wrote: Fri Jan 17, 2025 1:16 amOk, it's one of those black Pioneers with the UHD Blu Ray logo on the front. I updated the firmware on the drive to a pre-2022 firmware after this happened, so I don't have a screenshot, but I swear I opened it in MakeMKV and it said the firmware was some crazy thing not like the 1.5x or ID58 or whatever, and it said LibreDrive status: ENABLEDBillycar11 wrote: Thu Jan 16, 2025 11:43 pmThere is no unofficial pioneer firmware only old stuffhiddenvalley700 wrote: Thu Jan 16, 2025 10:51 pm INTERESTING FACT:
I own a Pioneer BDR-211M and a 212U. They look exactly alike and are known to be hard to flash and enable libredrive and what not. It turns out that my *refurbished* 211M was FLASHED with non-Pioneer firmware and is LibreDrive enabled.
My question is:
How would the previous owner have flashed the Pioneer? They did it somehow, but I'm having trouble figuring out how one would do that.
LibreDrive for Pioneer drives
hiddenvalley700
For the record, I updated the firmware to a pre-2022 version by editing the version number in the current download link on the Pioneer firmware page, and after I did that, it said LibreDrive was possible, not yet enabled, and it was actually able to play/rip UHD discs in that state.Billycar11 wrote: Fri Jan 17, 2025 2:07 amold pioneer fw is LibreDrive ENABLEDhiddenvalley700 wrote: Fri Jan 17, 2025 1:16 amOk, it's one of those black Pioneers with the UHD Blu Ray logo on the front. I updated the firmware on the drive to a pre-2022 firmware after this happened, so I don't have a screenshot, but I swear I opened it in MakeMKV and it said the firmware was some crazy thing not like the 1.5x or ID58 or whatever, and it said LibreDrive status: ENABLED
Before I updated the firmware, I swear it, the firmware said some wacky non Pioneer thing. I'm just putting it out there. You never know what's possible
closeyoureyes
Hi, I recently got a BDR-212U with firmware 1.0. Could someone help me make it possible with LibreDrive?
Thanks in advance.
Drive Information:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-212U
Revision: 1.00
Serial number: ************
Firmware date: 2019-01-10
Highest AACS version: 81
Drive platform: Pioneer RS8F01
Firmware version: ID83-
show us your makemkv drive info sectionhiddenvalley700 wrote: Fri Jan 17, 2025 8:47 amFor the record, I updated the firmware to a pre-2022 version by editing the version number in the current download link on the Pioneer firmware page, and after I did that, it said LibreDrive was possible, not yet enabled, and it was actually able to play/rip UHD discs in that state.Billycar11 wrote: Fri Jan 17, 2025 2:07 amold pioneer fw is LibreDrive ENABLEDhiddenvalley700 wrote: Fri Jan 17, 2025 1:16 am
sure email mecloseyoureyes wrote: Fri Jan 17, 2025 9:01 am Hi, I recently got a BDR-212U with firmware 1.0. Could someone help me make it possible with LibreDrive?Thanks in advance.Code: Select all
Drive Information: OS device name: E: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-212U Revision: 1.00 Serial number: ************ Firmware date: 2019-01-10 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F01 Firmware version: ID83
I just purchased a:
Product: BD-RW BDR-XS07U
Revision: 1.03
Firmware date: 2023-01-06
It states
Firmware version: ID05
When I try to decrypt a 4k UHD disk it isn't working. What do I need to do to get this drive to work?
Revision: 1.03
It states
Return it. Pioneer crippled the FW & so far. there is no means of undoing it.BryanS wrote: Mon Jan 27, 2025 1:36 pm I just purchased a:
Revision: 1.03
It states
edit: "Local" vendors still have access to Pioneer devices w/ older FW.
Hello!
I'm a new user and I've spent about 1.5hrs 'doing my homework'. From my current understanding, I think my drive should be supported, but must be added to the database.
I've attached a screenshot and included a text copy of the data to this comment.
If there is anything I need to do on my end, please let me know. Thank you very much.
OS device name: E:
Current profile: DVD-ROM
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: XXXXXXXXXXXX
Firmware date: 2022-12-27
Drive platform: Pioneer RS9331
Nope. You failed your homework! FDarkFiber wrote: Tue Jan 28, 2025 2:33 am Hello!![]()
If there is anything I need to do on my end, please let me know. Thank you very much.Code: Select all
Drive Information OS device name: E: Current profile: DVD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD08U Revision: 1.02 Serial number: XXXXXXXXXXXX Firmware date: 2022-12-27 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS9331 Firmware version: ID05![]()
Your drive is not supported and cannot be added to the firmware database at this time. It has the post 11/2022 firmware that has crippled any current form of compatibility. This issue has been worked on for 2+ years now with no end in sight.
Well shoot. Thanks for the reply though!
Ir hoped that because it was listed as "1.2" it might work. Oh well!
I still have a use for this drive and I can probably get one with a fully compatible firmware.
There should be enough publicly available AACSv1 device keys and host certificates that you won't need LibreDrive to play standard BluRays on that drive, even for those disks using bus encryption.DarkFiber wrote: Tue Jan 28, 2025 5:20 am I still have a use for this drive and I can probably get one with a fully compatible firmware.
I have a Pioneer BDR-X13U-S that tells me in MakeMKV "LibreDrive Status Possible, not yet enabled" Do I have any hope of dealing with UHD??
Darn thing was advertised as a 4K UHD drive!?
Post your Makemkv info.flight46 wrote: Sun Feb 02, 2025 9:41 pm I have a Pioneer BDR-X13U-S that tells me in MakeMKV "LibreDrive Status Possible, not yet enabled" Do I have any hope of dealing with UHD??
Product: BD-RW BDR-X13U
Revision: 1.03
Serial number: ...
Firmware date: 2022-12-12
Highest AACS version: 77
Firmware version: ID29
Revision: 1.03
Serial number: ...
No, you are out of luck. That drive has the dreaded post 11/2022 firmware and flashing has been disabled by Pioneer.flight46 wrote: Mon Feb 03, 2025 1:16 am Drive Information
Revision: 1.03
Serial number: ...
