Emailed dump file. Thanks!
MKB20_v77_Wicked_(Part_1)_BCA6.tgz
Dump Submitted - Wicked Part 1
Canda
Re: Dump Submitted - Wicked Part 1
Also submitted dump file
MrPenguin
captainbdsc
Once the dump is done being "done"? would it fix this?
It seemed to be ripping just fine until there was about 10mins left then it stalled and started getting errors.
MakeMKV v1.17.8 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\xxxx/MakeMKV_log.txt
Using LibreDrive mode (v06.3 id=4083C4CCDB14)
Downloading latest HK to C:\Users\xxxx/.MakeMKV ...
Using Java runtime from C:/Program Files/Java/jre1.8.0_441/bin/java.exe
Saving 1 titles into directory C:/Users/xxxx/Documents/Video - Transcode Needed
AV synchronization issues were found in file 'C:/Users/xxxx/Documents/Video - Transcode Needed/Wicked (Part 1)-SEG_MainFeature_t00.mkv' (title #1)
AV sync issue in stream 3 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +17ms
AV sync issue in stream 4 at 0:00:00 : 0 frame(s) dropped to reduce audio skew to +17ms
AV sync issue in stream 3,4 at 0:00:00 with duration of 17ms : encountered overlapping frame, audio skew is +17ms
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '77791229952'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '77800931328'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '77801453568'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '77801453568'
DEBUG: Code 3221225628 at e2ZHo%(J'4phL9N]&.:213131502
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '77802369024'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom0' at offset '77802369024'
DEBUG: Code 3221225653 at e2ZHo%(J'4phL9N]&.:213131502
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '77804470272'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '77805060096'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '77805060096'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '77805060096'
DEBUG: Code 100941314 at e2ZHo%(J'4phL9N]&.:213131502
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '77805385728'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom0' at offset '77805385728'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '77805385728'
DEBUG: Code 3221225488 at e2ZHo%(J'4phL9N]&.:213131502
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '77805385728'
DEBUG: Code 101000192 at e2ZHo%(J'4phL9N]&.:213131502
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:29395793
DEBUG: Code 0 at >{`y(>CqW-`Fca0ypbVz:29394068
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:213131157
DEBUG: Code 0 at MUklj]%J8Q@ \s=`g8hm:121262647
DEBUG: Code 37990911 at MUklj]%J8Q@ \s=`g8hm:121261773
DEBUG: Code 0 at r*4xP~>k4SvZ3d8pxZ:2I:121268972
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file C:/Users/xxxx/Documents/Video - Transcode Needed/Wicked (Part 1)-SEG_MainFeature_t00.mkv
Encountered 14 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Errors like this:
mean the optical drive was having trouble correctly reading a spot on the disc. The standard recommendation is to gently clean the disc, even if it is brand new, and try again.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '77791229952'-
captainbdsc
Grrrr...dcoke22 wrote: Tue Feb 04, 2025 11:19 pm Errors like this:mean the optical drive was having trouble correctly reading a spot on the disc. The standard recommendation is to gently clean the disc, even if it is brand new, and try again.Code: Select all
Yea, what you can "see" on the disc is not relevant. A lot of times they come with an oily film on them. I personally use dawn dish liquid (hey good enough for ducks, good enough for discs LMAO) and a microfiber cloth. The type of drive can certainly make a difference. I've not had to touch a disc in a long time since I switched to Pio drives. But from time to time, discs are just poorly manufactured. It happens.
(And yes, I've seen fingerprints on brand new discs, as well. The manufacturing process is....ahem....less than ideal LOL)
jtscribe
Guessing _t12 is the sing-along version? Anyone rip both?
sbcadguy
I had the same issues reading the Wicked disk. Exchanged it through Amazon and the replacement ripped without issue. I've had this problem with a few disks.
The sing a long is just a subtitle track (track 4) on the "MainFeature".
Cerina
Submitted
MKB20_v77_Wicked_(Part_1)_11BA
agentbrowder
Submitted
MKB20_v77_Wicked_(Part_1)_C0F4.tgz
Tried the latest KEYDB.cfg file - no luck.
Also attached for keydb_helper.
keydb_helper
Thank you for providing the file but disc dumps produced with Pioneer drives are of limited use. Would you happen to have an LG or Asus drive as an alternative?agentbrowder wrote: Wed Feb 26, 2025 2:52 am Submitted
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
agentbrowder
Unfortunately, no, my LG drive died on me.keydb_helper wrote: Wed Feb 26, 2025 11:00 am Thank you for providing the file but disc dumps produced with Pioneer drives are of limited use. Would you happen to have an LG or Asus drive as an alternative?
MrPenguin
How dead? Does the laser still work? The drive would only need to be able to mount the disk, it wouldn't need to be able to read it completely.
agentbrowder
Very dead - it won't mount any disk. Tried different cables, computers, OS's. Same result.MrPenguin wrote: Wed Feb 26, 2025 8:28 pm How dead? Does the laser still work? The drive would only need to be able to mount the disk, it wouldn't need to be able to read it completely.
