Coraline Dump File Submitted
MKB20_v77_CORALINE_4A3A
Re: Coraline Dump File Submitted
Yes. It does not work.
keydb_helper
The 4A3A variant of Coraline has been added to the public keydb.
If you re-download the keydb or sync it with SamuriHL's utility (Link) you will be able to decrypt your disc.
Public KeyDB Disc Submissions
That was quick, thank you very much!
Coraline is as added ages ago
I suspect new "Coraline" disks have recently been released.
I have the latest steelbook version and it rips just fine, maybe different countries may not have been decrypted but uk and USA have been
