Coraline Dump File Submitted
waffel
Post by waffel »
MKB20_v77_CORALINE_4A3A
MrPenguin
Re: Coraline Dump File Submitted
Post by MrPenguin »
waffel wrote:
Thu Jan 30, 2025 12:30 pm
waffel
Post by waffel »
MrPenguin wrote:
Thu Jan 30, 2025 12:35 pm
Yes. It does not work.
keydb_helper
Post by keydb_helper »
waffel wrote:
Thu Jan 30, 2025 12:41 pm
The 4A3A variant of Coraline has been added to the public keydb.
If you re-download the keydb or sync it with SamuriHL's utility (Link) you will be able to decrypt your disc.
Public KeyDB Disc Submissions
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
waffel
Post by waffel »
That was quick, thank you very much!
Peterduke
Post by Peterduke »
Coraline is as added ages ago
MrPenguin
Post by MrPenguin »
Peterduke wrote:
Fri Jan 31, 2025 7:49 pm
I suspect new "Coraline" disks have recently been released.
Peterduke
Post by Peterduke »
MrPenguin wrote:
Sat Feb 01, 2025 1:07 am
I have the latest steelbook version and it rips just fine, maybe different countries may not have been decrypted but uk and USA have been
