Coraline Dump File Submitted
MKB20_v77_CORALINE_4A3A
Re: Coraline Dump File Submitted
Yes. It does not work.
keydb_helper
The 4A3A variant of Coraline has been added to the public keydb.
If you re-download the keydb or sync it with SamuriHL's utility (Link) you will be able to decrypt your disc.
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
That was quick, thank you very much!
Coraline is as added ages ago
I suspect new "Coraline" disks have recently been released.
I have the latest steelbook version and it rips just fine, maybe different countries may not have been decrypted but uk and USA have been
