Purchased from Gruv in Jan 2025, Oceans 11 and 13 fail to decrypt, 12 worked fine.
MKB20_v77_OCEANS_ELEVEN_3874
MKB20_v77_OCEANS_THIRTEEN_6448
Dump Submitted - Ocean's Trilogy
Re: Dump Submitted - Ocean's Trilogy
Same thing here. Thanks for submitting it.
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?scaldeddog79 wrote: ↑Fri Jan 24, 2025 8:05 pmMKB20_v77_OCEANS_ELEVEN_3874
I just tried this. Same result.MrPenguin wrote: ↑Sun Jan 26, 2025 10:00 pmHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?scaldeddog79 wrote: ↑Fri Jan 24, 2025 8:05 pmMKB20_v77_OCEANS_ELEVEN_3874
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Saved AACS dump file as C:\Users\dyaus/.MakeMKV/MKB20_v77_Ocean's_Thirteen_6448.tgz
Saved AACS dump file as C:\Users\dyaus/.MakeMKV/MKB20_v77_Ocean's_Eleven_3874.tgz
Failed to open discRe: Dump Submitted - Ocean's Trilogy
KEYDB is a public database, and is populated by submissions from people who own copies of these disks. Your MakeMKV dumps might help people here add those disks for you, if you can make them available somehow? E.g. uploading them here as attachments, or links to (say) Google Drive or OneDrive?
I uploaded these two dumps to Google Drive here: https://drive.google.com/drive/folders/ ... drive_link
Will remove in a week or two
the1truebiscuit
Same exact situation for me. Thank you for reporting.scaldeddog79 wrote: ↑Fri Jan 24, 2025 8:05 pmPurchased from Gruv in Jan 2025, Oceans 11 and 13 fail to decrypt, 12 worked fine.
Sorry, I'm relatively new to the participation side of the forum and don't think I was clear enough. My dump filenames match OP's and I didn't want to duplicate requests. Should I go ahead and include them?MrPenguin wrote: ↑Tue Jan 28, 2025 11:03 amKEYDB is a public database, and is populated by submissions from people who own copies of these disks. Your MakeMKV dumps might help people here add those disks for you, if you can make them available somehow? E.g. uploading them here as attachments, or links to (say) Google Drive or OneDrive?
Now I see that you weren't talking to me. My bad.
keydb_helper
Thank you providing suitable disc dump files. The 3874 variant of Ocean's Eleven and the 6448 variant of Ocean's Thirteen have been added to the public keydb.dyaus7 wrote: ↑Tue Jan 28, 2025 6:13 pmI uploaded these two dumps to Google Drive here: https://drive.google.com/drive/folders/ ... drive_link
If you haven't previously configured the public keydb you can follow my instructions here. If you are already utilising the public keydb, re-download it or sync with FindVUK to get the latest keys. Remember, MakeMKV will eventually provide native support for these particular discs but it might take several days or weeks. Until that time the public keydb is a neat option.
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Worked for me. Thank you!
the1truebiscuit
This has now been resolved natively on MakeMKV. Thank you again for submitting!
