LibreDrive for Pioneer drives
#1276 Post by Billycar11 » Fri Jan 17, 2025 2:07 am
hiddenvalley700 wrote: Fri Jan 17, 2025 1:16 am
Billycar11 wrote: Thu Jan 16, 2025 11:43 pm
hiddenvalley700 wrote: Thu Jan 16, 2025 10:51 pm INTERESTING FACT:
I own a Pioneer BDR-211M and a 212U. They look exactly alike and are known to be hard to flash and enable libredrive and what not. It turns out that my *refurbished* 211M was FLASHED with non-Pioneer firmware and is LibreDrive enabled.
My question is:
How would the previous owner have flashed the Pioneer? They did it somehow, but I'm having trouble figuring out how one would do that.
There is no unofficial pioneer firmware only old stuff
Ok, it's one of those black Pioneers with the UHD Blu Ray logo on the front. I updated the firmware on the drive to a pre-2022 firmware after this happened, so I don't have a screenshot, but I swear I opened it in MakeMKV and it said the firmware was some crazy thing not like the 1.5x or ID58 or whatever, and it said LibreDrive status: ENABLED
old pioneer fw is LibreDrive ENABLED
hiddenvalley700
#1277 Post by hiddenvalley700 » Fri Jan 17, 2025 8:47 am
Billycar11 wrote: Fri Jan 17, 2025 2:07 am
For the record, I updated the firmware to a pre-2022 version by editing the version number in the current download link on the Pioneer firmware page, and after I did that, it said LibreDrive was possible, not yet enabled, and it was actually able to play/rip UHD discs in that state.
Before I updated the firmware, I swear it, the firmware said some wacky non Pioneer thing. I'm just putting it out there. You never know what's possible
closeyoureyes
#1278 Post by closeyoureyes » Fri Jan 17, 2025 9:01 am
Hi, I recently got a BDR-212U with firmware 1.0. Could someone help me make it possible with LibreDrive?
Drive Information:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-212U
Revision: 1.00
Serial number: ************
Firmware date: 2019-01-10
Highest AACS version: 81
Drive platform: Pioneer RS8F01
Firmware version: ID83
Thanks in advance.
#1279 Post by Billycar11 » Fri Jan 17, 2025 11:01 am
hiddenvalley700 wrote: Fri Jan 17, 2025 8:47 am
show us your makemkv drive info section
#1280 Post by Billycar11 » Fri Jan 17, 2025 11:02 am
closeyoureyes wrote: Fri Jan 17, 2025 9:01 am Hi, I recently got a BDR-212U with firmware 1.0. Could someone help me make it possible with LibreDrive?
Drive Information:
OS device name: E:
Revision: 1.00
Thanks in advance.
sure email me
BryanS
#1281 Post by BryanS » Mon Jan 27, 2025 1:36 pm
I just purchased a:
Product: BD-RW BDR-XS07U
Revision: 1.03
Firmware date: 2023-01-06
It states
Firmware version: ID05
When I try to decrypt a 4k UHD disk it isn't working. What do I need to do to get this drive to work?
#1282 Post by d00zah » Mon Jan 27, 2025 1:44 pm
BryanS wrote: Mon Jan 27, 2025 1:36 pm I just purchased a:
Revision: 1.03
It states
Return it. Pioneer crippled the FW & so far. there is no means of undoing it.
edit: "Local" vendors still have access to Pioneer devices w/ older FW.
DarkFiber
#1283 Post by DarkFiber » Tue Jan 28, 2025 2:33 am
Hello! :D
I'm a new user and I've spent about 1.5hrs 'doing my homework'. From my current understanding, I think my drive should be supported, but must be added to the database.
I've attached a screenshot and included a text copy of the data to this comment.
If there is anything I need to do on my end, please let me know. Thank you very much.
OS device name: E:
Current profile: DVD-ROM
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: XXXXXXXXXXXX
Firmware date: 2022-12-27
Drive platform: Pioneer RS9331
#1284 Post by MartyMcNuts » Tue Jan 28, 2025 3:40 am
DarkFiber wrote: Tue Jan 28, 2025 2:33 am Hello! :D
OS device name: E:
Revision: 1.02
Nope. You failed your homework! F :D
Your drive is not supported and cannot be added to the firmware database at this time. It has the post 11/2022 firmware that has crippled any current form of compatibility. This issue has been worked on for 2+ years now with no end in sight.
DarkFiber
#1285 Post by DarkFiber » Tue Jan 28, 2025 5:20 am
Well shoot. Thanks for the reply though!
Ir hoped that because it was listed as "1.2" it might work. Oh well!
I still have a use for this drive and I can probably get one with a fully compatible firmware.
MrPenguin
#1286 Post by MrPenguin » Tue Jan 28, 2025 11:21 am
DarkFiber wrote: Tue Jan 28, 2025 5:20 am I still have a use for this drive and I can probably get one with a fully compatible firmware.
There should be enough publicly available AACSv1 device keys and host certificates that you won't need LibreDrive to play standard BluRays on that drive, even for those disks using bus encryption.
flight46
#1287 Post by flight46 » Sun Feb 02, 2025 9:41 pm
I have a Pioneer BDR-X13U-S that tells me in MakeMKV "LibreDrive Status Possible, not yet enabled" Do I have any hope of dealing with UHD??
Darn thing was advertised as a 4K UHD drive!?
#1288 Post by Coopervid » Sun Feb 02, 2025 10:58 pm
flight46 wrote: Sun Feb 02, 2025 9:41 pm I have a Pioneer BDR-X13U-S that tells me in MakeMKV "LibreDrive Status Possible, not yet enabled" Do I have any hope of dealing with UHD??
Post your Makemkv info.
flight46
#1289 Post by flight46 » Mon Feb 03, 2025 1:16 am
Product: BD-RW BDR-X13U
Revision: 1.03
Serial number: ...
Firmware date: 2022-12-12
Highest AACS version: 77
Firmware version: ID29
#1290 Post by MartyMcNuts » Mon Feb 03, 2025 2:02 am
flight46 wrote: Mon Feb 03, 2025 1:16 am Drive Information
Revision: 1.03
Serial number: ...
No, you are out of luck. That drive has the dreaded post 11/2022 firmware and flashing has been disabled by Pioneer.
