Saved AACS dump file as C:\Users\CXXX/.MakeMKV/MKB20_v77_Miracles_the_canton_godfather_ADD8.tgz
Backup failed
Does anyone have KEYDB.cfg?
Can you provide one. Thanks!
Dump Submitted - MKB20_v77_Miracles_the_canton_godfather_ADD8.tgz
Queer
MrPenguin
Re: Dump Submitted - MKB20_v77_Miracles_the_canton_godfather_ADD8.tgz
You just download the latest KEYDB.cfg file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.
There's no guarantee that the KEYDB.cfg file will contain the key for your disk though. Especially for brand new disks.
viewtopic.php?f=12&t=16883&p=166510#p166510
If you're on windows, download that. It'll sync the keydb for you and check if your disc is supported in it.
Queer
It's just a new disc, but downloading KEYDB.cfg still doesn't work.
keydb_helper
Titles can't really be added to the public keydb in a form usable by MakeMKV unless someone provides a disc dump file either as a forum attachment or a link to a file host.Queer wrote: Tue Jan 21, 2025 1:52 pm It's just a new disc, but downloading KEYDB.cfg still doesn't work.
Ideally this disc dump should be produced by an LG or Asus drive as support for Pioneer drives is somewhat limited.
Public KeyDB Disc Submissions
Queer
Okay, but I accidentally deleted this disc dump file. Fortunately, this disc can now be opened normally.
Queer
Also, can we add another disc to the public keydb.cfg.
Queer
The Disc dump file has been found, Can you add it to the public keydb.cfg as well.
keydb_helper
Thanks for providing suitable disc dumps. Both An Autumn's Tale and Miracles: The Canton Godfather have been added to the public keydb.Queer wrote: Fri Jan 24, 2025 6:25 pm The Disc dump file has been found, Can you add it to the public keydb.cfg as well.
Queer
Ok, thank you very much!
