Dump Submitted - MKB20_v77_Miracles_the_canton_godfather_ADD8.tgz
Queer
#1 Post by Queer » Mon Jan 20, 2025 5:09 pm
Saved AACS dump file as C:\Users\CXXX/.MakeMKV/MKB20_v77_Miracles_the_canton_godfather_ADD8.tgz
Backup failed
Does anyone have KEYDB.cfg?
Can you provide one. Thanks!
MrPenguin
Re: Dump Submitted - MKB20_v77_Miracles_the_canton_godfather_ADD8.tgz
#2 Post by MrPenguin » Mon Jan 20, 2025 5:13 pm
Queer wrote: Mon Jan 20, 2025 5:09 pm Does anyone have KEYDB.cfg?
You just download the latest KEYDB.cfg file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.
There's no guarantee that the KEYDB.cfg file will contain the key for your disk though. Especially for brand new disks.
#3 Post by SamuriHL » Mon Jan 20, 2025 5:29 pm
viewtopic.php?f=12&t=16883&p=166510#p166510
If you're on windows, download that. It'll sync the keydb for you and check if your disc is supported in it.
Queer
#4 Post by Queer » Tue Jan 21, 2025 1:52 pm
It's just a new disc, but downloading KEYDB.cfg still doesn't work.
keydb_helper
#5 Post by keydb_helper » Tue Jan 21, 2025 2:27 pm
Queer wrote: Tue Jan 21, 2025 1:52 pm It's just a new disc, but downloading KEYDB.cfg still doesn't work.
Titles can't really be added to the public keydb in a form usable by MakeMKV unless someone provides a disc dump file either as a forum attachment or a link to a file host.
Ideally this disc dump should be produced by an LG or Asus drive as support for Pioneer drives is somewhat limited.
Public KeyDB Disc Submissions
KeyDB Download
Queer
#6 Post by Queer » Fri Jan 24, 2025 5:55 pm
Okay, but I accidentally deleted this disc dump file. Fortunately, this disc can now be opened normally.
Queer
#7 Post by Queer » Fri Jan 24, 2025 6:11 pm
Also, can we add another disc to the public keydb.cfg.
Queer
#8 Post by Queer » Fri Jan 24, 2025 6:25 pm
The Disc dump file has been found, Can you add it to the public keydb.cfg as well.
keydb_helper
#9 Post by keydb_helper » Sat Jan 25, 2025 1:31 am
Queer wrote: Fri Jan 24, 2025 6:11 pm Also, can we add another disc to the public keydb.cfg.
Queer wrote: Fri Jan 24, 2025 6:25 pm The Disc dump file has been found, Can you add it to the public keydb.cfg as well.
Thanks for providing suitable disc dumps. Both An Autumn's Tale and Miracles: The Canton Godfather have been added to the public keydb.
KeyDB Download
Queer
#10 Post by Queer » Sat Jan 25, 2025 8:20 pm
Ok, thank you very much!
