MrPenguin
Post
by MrPenguin » Tue Jan 21, 2025 12:36 pm
el_vandragon wrote: ↑Mon Jan 20, 2025 11:32 pm
Submitted filename:
Have you tried downloading the latest
KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
el_vandragon
Post
by el_vandragon » Wed Jan 22, 2025 7:34 am
MrPenguin wrote: ↑Tue Jan 21, 2025 12:36 pm
Downloaded one dated
and it did not work, I tried with the default name of "keydb.cfg" and then re-tried with it named as "KEYDB.cfg" and neither worked. I put it in
MrPenguin
Post
by MrPenguin » Wed Jan 22, 2025 3:13 pm
el_vandragon wrote: ↑Wed Jan 22, 2025 7:34 am
and it did not work.
Then could you add your TGZ dump file as an attachment, or upload it into (say) Google Drive or OneDrive and reply with a link please? This could (potentially) allow people to add your disk to KEYDB.
el_vandragon
Post
by el_vandragon » Wed Jan 22, 2025 5:49 pm
MrPenguin wrote: ↑Wed Jan 22, 2025 3:13 pm
Sure, I can add it as an attachment here.
- MKB20_v77_PULP_FICTION_C42D.tgz
- (239.43 KiB) Downloaded 115 times
MrPenguin
Post
by MrPenguin » Thu Jan 23, 2025 11:51 am
el_vandragon wrote: ↑Wed Jan 22, 2025 5:49 pm
Thanks, this dump file looks worryingly small though - I would have expected it to be about 3 MiB.
Post
by SamuriHL » Thu Jan 23, 2025 2:14 pm
Doesn't matter, it already has a full entry in the keydb:
Disc ID: 0x2637EE08F12D2647DD22A9663C5733C5B7741C95
el_vandragon
Post
by el_vandragon » Thu Jan 23, 2025 5:43 pm
SamuriHL wrote: ↑Thu Jan 23, 2025 2:14 pm
Very nice! I messed around and got FindVUK to run but it only seemed to add the Unit Key at the time, so it is nice that the rest of the data was able to be populated. Trying a dump with latest KEYDB.cfg and it seems to be working now. I will re-test after without KEYDB to see if the hashed-key has been added to MakeMKV or not.
Post
by SamuriHL » Thu Jan 23, 2025 5:44 pm
I'm guessing someone grabbed your dump from this thread and was able to add the full keydb entry for it. That is always nice.
