The Ministry of Ungentlemanly Warfare 4k unable to copy
jt5298
Post by jt5298 »
Has anyone ripped this disc? I see a dump file was sent a month ago.
viewtopic.php?f=12&t=34443
I downloaded the online key, and it looks like the key is there?
0xA62AE142D8C5C1FC9731E0E8E70A15483AD915F0 = MINISTRY_UNGENTLEMANLY_WARFARE (The Ministry Of Ungentlemanly Warfare - Ultra HD Blu-ray™) | D | 2024-05-02 | V | 0x69C77EEEB0B49291126EDE98D4DA721B | M | 0x264E780075D00DF840D6396A4A25FBE2 | I | 0x262F6C8419959E75C932F9B78895A913 | U | 1-0x48AF9BD3703FFFDA0EEEC9F5CB2D9361 ; MKBv77/BEE - VolumeSize: 85371453440 (UHD) (LEGACY) (NOTVALIDATED) (BD)
tribunal88
Re: The Ministry of Ungentlemanly Warfare 4k unable to copy
Post by tribunal88 »
I just got this for Christmas and its failing with the following error:
DEBUG: Code 0 at VtT$hoa+N}'B:VS3:29398070
Saved AACS dump file as d:\Users\<usernam>/.MakeMKV/MKB20_v77_The_Ministry_Of_Ungentlemanly_Warfare_D8A0.tgz
DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213132721
DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213131341
MrPenguin
Post by MrPenguin »
tribunal88 wrote: Fri Dec 27, 2024 10:10 pm I just got this for Christmas and its failing with the following error:
tribunal88
That worked.
richwill
Post by richwill »
I also received a copy of this at Christmas and have been unable to decrypt it. I checked the hash of the Unit_Key_RO.inf (CAD8FDA6528FE6A6D08D2DFC18B935CE16E0242B) and confirmed it's not in the most recent keydb.cfg.
I emailed the tgz file a few times, but no update. I'm only using linux, and don't have access to run FindVUK at this point. I could potentialy install Windows somewhere just for this, but if someone has solved this, it would be great.
Thanks to help here, the key was added. Thanks again!
MrPenguin
Post by MrPenguin »
richwill wrote: Tue Jan 21, 2025 9:19 pm I'm only using linux, and don't have access to run FindVUK at this point.
FindVUK works fine on Linux using Wine's wineconsole.
richwill
Post by richwill »
I will dig into running FindVUK locally. Thanks for that tip as well!
MrPenguin
Post by MrPenguin »
richwill wrote: Wed Jan 22, 2025 2:49 pm I will dig into running FindVUK locally. Thanks for that tip as well!
No worries. BTW you don't need DVDFab in order to run either "findvuk synchronize" or "findvuk validateDisc".
