Dumped US Pulp Fiction 4k UHD
el_vandragon
Post by el_vandragon » Mon Jan 20, 2025 11:32 pm
Submitted filename:
MKB20_v77_PULP_FICTION_C42D.tgz
MrPenguin
Re: Dumped US Pulp Fiction 4k UHD
Post by MrPenguin » Tue Jan 21, 2025 12:36 pm
el_vandragon wrote: Mon Jan 20, 2025 11:32 pm Submitted filename:
el_vandragon
Post by el_vandragon » Wed Jan 22, 2025 7:34 am
MrPenguin wrote: Tue Jan 21, 2025 12:36 pm Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
Downloaded one dated
and it did not work, I tried with the default name of "keydb.cfg" and then re-tried with it named as "KEYDB.cfg" and neither worked. I put it in
C:\Users\el_vandragon\.MakeMKV
MrPenguin
Post by MrPenguin » Wed Jan 22, 2025 3:13 pm
el_vandragon wrote: Wed Jan 22, 2025 7:34 am Downloaded one dated
and it did not work.
Then could you add your TGZ dump file as an attachment, or upload it into (say) Google Drive or OneDrive and reply with a link please? This could (potentially) allow people to add your disk to KEYDB.
el_vandragon
Post by el_vandragon » Wed Jan 22, 2025 5:49 pm
MrPenguin wrote: Wed Jan 22, 2025 3:13 pm Then could you add your TGZ dump file as an attachment, or upload it into (say) Google Drive or OneDrive and reply with a link please? This could (potentially) allow people to add your disk to KEYDB.
Sure, I can add it as an attachment here.
(239.43 KiB) Downloaded 206 times
MrPenguin
Post by MrPenguin » Thu Jan 23, 2025 11:51 am
el_vandragon wrote: Wed Jan 22, 2025 5:49 pm Sure, I can add it as an attachment here.
Thanks, this dump file looks worryingly small though - I would have expected it to be about 3 MiB.
Post by SamuriHL » Thu Jan 23, 2025 2:14 pm
Doesn't matter, it already has a full entry in the keydb:
Disc ID: 0x2637EE08F12D2647DD22A9663C5733C5B7741C95
el_vandragon
Post by el_vandragon » Thu Jan 23, 2025 5:43 pm
SamuriHL wrote: Thu Jan 23, 2025 2:14 pm Doesn't matter, it already has a full entry in the keydb:
Very nice! I messed around and got FindVUK to run but it only seemed to add the Unit Key at the time, so it is nice that the rest of the data was able to be populated. Trying a dump with latest KEYDB.cfg and it seems to be working now. I will re-test after without KEYDB to see if the hashed-key has been added to MakeMKV or not.
Post by SamuriHL » Thu Jan 23, 2025 5:44 pm
I'm guessing someone grabbed your dump from this thread and was able to add the full keydb entry for it. That is always nice. :)
