The Ministry of Ungentlemanly Warfare 4k unable to copy
jt5298
#1 Post by jt5298 » Tue Jul 23, 2024 2:43 am
Has anyone ripped this disc? I see a dump file was sent a month ago.
viewtopic.php?f=12&t=34443
I downloaded the online key, and it looks like the key is there?
0xA62AE142D8C5C1FC9731E0E8E70A15483AD915F0 = MINISTRY_UNGENTLEMANLY_WARFARE (The Ministry Of Ungentlemanly Warfare - Ultra HD Blu-ray™) | D | 2024-05-02 | V | 0x69C77EEEB0B49291126EDE98D4DA721B | M | 0x264E780075D00DF840D6396A4A25FBE2 | I | 0x262F6C8419959E75C932F9B78895A913 | U | 1-0x48AF9BD3703FFFDA0EEEC9F5CB2D9361 ; MKBv77/BEE - VolumeSize: 85371453440 (UHD) (LEGACY) (NOTVALIDATED) (BD)
tribunal88
Re: The Ministry of Ungentlemanly Warfare 4k unable to copy
#2 Post by tribunal88 » Fri Dec 27, 2024 10:10 pm
I just got this for Christmas and its failing with the following error:
DEBUG: Code 0 at VtT$hoa+N}'B:VS3:29398070
Saved AACS dump file as d:\Users\<usernam>/.MakeMKV/MKB20_v77_The_Ministry_Of_Ungentlemanly_Warfare_D8A0.tgz
DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213132721
DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213131341
MrPenguin
#3 Post by MrPenguin » Fri Dec 27, 2024 10:34 pm
tribunal88
#4 Post by tribunal88 » Tue Dec 31, 2024 3:10 pm
That worked.
richwill
#5 Post by richwill » Tue Jan 21, 2025 9:19 pm
I also received a copy of this at Christmas and have been unable to decrypt it. I checked the hash of the Unit_Key_RO.inf (CAD8FDA6528FE6A6D08D2DFC18B935CE16E0242B) and confirmed it's not in the most recent keydb.cfg.
I emailed the tgz file a few times, but no update. I'm only using linux, and don't have access to run FindVUK at this point. I could potentialy install Windows somewhere just for this, but if someone has solved this, it would be great.
Thanks to help here, the key was added. Thanks again!
MrPenguin
#6 Post by MrPenguin » Tue Jan 21, 2025 9:24 pm
FindVUK works fine on Linux using Wine's wineconsole.
richwill
#7 Post by richwill » Wed Jan 22, 2025 2:49 pm
I will dig into running FindVUK locally. Thanks for that tip as well!
MrPenguin
#8 Post by MrPenguin » Wed Jan 22, 2025 4:05 pm
No worries. BTW you don't need DVDFab in order to run either "findvuk synchronize" or "findvuk validateDisc".
