MKB20_v61_The_Matrix_BE51
MKB20_v65_The_Matrix_Reloaded_CCBB
MKB20_v65_The_Matrix_Revolutions_AAE1
MKB20_v76_The_Matrix_Resurrections_FF47Code: Select all
MKB20_v76_The_Matrix_Resurrections_FF47Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?AnBird wrote: Wed Jan 22, 2025 3:05 am Dumps have been submitted for the following discs found in the Matrix box set:Code: Select all
MKB20_v61_The_Matrix_BE51 MKB20_v65_The_Matrix_Reloaded_CCBB MKB20_v65_The_Matrix_Revolutions_AAE1 MKB20_v76_The_Matrix_Resurrections_FF47
That solution solved my issue, thanks a lot!MrPenguin wrote: Wed Jan 22, 2025 11:11 amHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?AnBird wrote: Wed Jan 22, 2025 3:05 am Dumps have been submitted for the following discs found in the Matrix box set:
That site isn't working for me?MrPenguin wrote: Wed Jan 22, 2025 11:11 amHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?AnBird wrote: Wed Jan 22, 2025 3:05 am Dumps have been submitted for the following discs found in the Matrix box set:Code: Select all
I'm pretty sure that site is not https, so if your browser requires https you'll need to change settings or get a different browser.
