Saved AACS dump file as C:\Users\CXXX/.MakeMKV/MKB20_v77_Miracles_the_canton_godfather_ADD8.tgz
Backup failed
Does anyone have KEYDB.cfg?
Can you provide one. Thanks!
Dump Submitted - MKB20_v77_Miracles_the_canton_godfather_ADD8.tgz
Re: Dump Submitted - MKB20_v77_Miracles_the_canton_godfather_ADD8.tgz
You just download the latest KEYDB.cfg file, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restart MakeMKV.
There's no guarantee that the KEYDB.cfg file will contain the key for your disk though. Especially for brand new disks.
viewtopic.php?f=12&t=16883&p=166510#p166510
If you're on windows, download that. It'll sync the keydb for you and check if your disc is supported in it.
It's just a new disc, but downloading KEYDB.cfg still doesn't work.
keydb_helper
Titles can't really be added to the public keydb in a form usable by MakeMKV unless someone provides a disc dump file either as a forum attachment or a link to a file host.
Ideally this disc dump should be produced by an LG or Asus drive as support for Pioneer drives is somewhat limited.
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Okay, but I accidentally deleted this disc dump file. Fortunately, this disc can now be opened normally.
Also, can we add another disc to the public keydb.cfg.
The Disc dump file has been found, Can you add it to the public keydb.cfg as well.
keydb_helper
Thanks for providing suitable disc dumps. Both An Autumn's Tale and Miracles: The Canton Godfather have been added to the public keydb.
Ok, thank you very much!
