Dump Submitted - The Blues Brothers 4K Extended Version
uhd-4k-fan
#1 Post by uhd-4k-fan » Sun Jan 19, 2025 6:26 pm
Received a couple of days ago.
MKB20_v70_The_Blues_Brothers_4K_Extended_Version_7FE9.tgz
MrPenguin
Re: Dump Submitted - The Blues Brothers 4K Extended Version
#2 Post by MrPenguin » Sun Jan 19, 2025 9:44 pm
uhd-4k-fan
#3 Post by uhd-4k-fan » Mon Jan 20, 2025 6:20 pm
Yes, did that.
Also check the disc ID and the disc is not in KEYDB.cfg, yet.
uhd-4k-fan
#4 Post by uhd-4k-fan » Wed Jan 22, 2025 9:05 pm
Dump as attachment if someone can make use of it to get it added to the keydb.
Be aware the dump is created using a Pioneer drive.
MrPenguin
#5 Post by MrPenguin » Thu Jan 23, 2025 11:43 am
If you're a Windows user then you might be able to decrypt your disk using MakeMKV with Xreveal. This would only require KEYDB.cfg to contain a Unit Key ("| U |" record), instead of needing a Volume Unique Key ("| V |" record).
#6 Post by SamuriHL » Thu Jan 23, 2025 2:32 pm
That dump is highly broken. Nonetheless the full record including the VUK has been uploaded to the KeyDB.
MrPenguin
#7 Post by MrPenguin » Thu Jan 23, 2025 5:10 pm
Actually, that dump was created by a Verbatim 43888, which means that the VID is almost certainly wrong. And hence the VUK calculated from it will be wrong too :(.
Hopefully the Unit Key still checks out though.
#8 Post by SamuriHL » Thu Jan 23, 2025 5:31 pm
That means there's a bug in my code as it checks for that situation...I'll deal with that. So yes, the VUK that's been uploaded would be wrong. That sucks.
If anyone happens to have that disc and can make a non-verbatim pioneer drive dump and can post it that would be helpful.
MrPenguin
#9 Post by MrPenguin » Thu Jan 23, 2025 8:16 pm
Even more useful, could any Windows user who has this disk please validate its KEYDB entry using FindVUK? Specifically, and assuming your UHD drive is F:
  • Edit your FindVUK.ini file to contain
    Disable_Bus_Encryption_Cmd = "C:\Program Files (x86)\MakeMKV\makemkvcon.exe" info dev:$DRIVE$
    assuming you have installed MakeMKV in "C:\Program Files (x86)\MakeMKV".
  • Execute
    findvuk synchronize
    to ensure FindVUK's copy of KEYDB.cfg is up-to-date.
  • Then put your disk in your UHD drive, wait for Windows to mount it, and then execute
    findvuk validateDisc drive=F
The relevant record in KEYDB.cfg starts with:
0x60FD85412E2AFBFBDB39BD160A5308CBB1497BDF = BLUES BROTHERS 4K UHD EXTENDED (The Blues Brothers 4K Extended Version - Blu-ray™) | D | 2022-06-14
I strongly suspect that both its Volume ID ("| I |" field) and Volume Unique Key ("| V |" field) are incorrect, although both its "| U |" and "| M |" fields are probably OK. In which case, deleting both the "I" and "V" fields should allow "findvuk validateDisc" to succeed.
This is probably the only way to correct the record :(.
#10 Post by SamuriHL » Thu Jan 23, 2025 8:26 pm
Very likely. This particular dump file was problematic which exacerbated my code's issue. It'll be fixed for next time.
uhd-4k-fan
#11 Post by uhd-4k-fan » Fri Jan 31, 2025 4:29 pm
New dump with a different drive.
#12 Post by SamuriHL » Fri Jan 31, 2025 5:14 pm
Looks like someone already fixed that entry in the keydb. It should work with MakeMKV now.
MrPenguin
#13 Post by MrPenguin » Fri Jan 31, 2025 11:43 pm
No, that entry's VID and VUK still look broken to me :(. However, I am confident that running
findvuk validateDisc drive=<your uhd drive letter>
could fix it.
#14 Post by SamuriHL » Sat Feb 01, 2025 12:23 am
Yea I tried uploading the fixed entry and it won't accept it. When I resynced the keydb it reverted what I changed. Lovely.
uhd-4k-fan
#15 Post by uhd-4k-fan » Sat Feb 01, 2025 8:48 am
findvuk only gives me:
09:47:37 - Get basic AACS data
09:47:37 - AACS folder on disc is reachable - Validate is possible
09:47:37 - Failed to init disc >AACS UNKNOWN ERROR >-1501<<
But it rips fine with MakeMKV HK now.
